• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    3ds Max Design 2013 Insatallatioan Fails
    3775 Views, 12 Replies
    04-20-2012 07:27 AM
    I have attached the setup log for anyone that knows what any of that means.
    Below is what it basically says:
    2012/4/20:10:15:55    Dan    MACHV    === Setup started on MACHV by Dan ===
    2012/4/20:10:15:55    Dan    MACHV    Launch
    2012/4/20:10:15:58    Dan    MACHV    PageOpen    LaunchDialog
    2012/4/20:10:16:37    Dan    MACHV    PageOpen    LicenseDialog
    2012/4/20:10:16:39    Dan    MACHV    PageOpen    ProductInfoDialog
    2012/4/20:10:17:06    Dan    MACHV    PageOpen    ProductSelectionDialog2
    2012/4/20:10:17:08    Dan    MACHV    PageOpen    FullProgressDialog
    2012/4/20:10:17:08    Dan    MACHV    Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_Design_2013_EFGKJS_Win_64bit
    \3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:F:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dan\AppData
    \Local\Temp\vcredist_x86_2005.log"" "
    2012/4/20:10:17:09    Dan    MACHV    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted,
    Result=1603
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: 3ds Max Design 2013 Insatallatioan Fails
    04-20-2012 08:50 AM in reply to: drblack
    Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
    For more information about this process, please see my KB link here:
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    04-20-2012 10:30 AM in reply to: drblack
    Thanks for the reply.  Problem...when I try to uninstall the prerequistie program I get a Windows Installer error message -
    "The Windows Installer Service could not be accessed.  This can occur if the Windows Installer is not correctly installed.  Contact your support personnel for assistance."
    I cannot seem to make an headway.
    *Expert Elite*
    TravisNave
    04-20-2012 10:52 AM in reply to: drblack
    Yikes, sounds like you're having all kinds of fun.  See if you can update/reinstall the Windows Installer:
    http://support.microsoft.com/kb/942288
    Travis Nave
    Active Member
    04-20-2012 11:20 AM in reply to: TravisNave
    Yeah having a great old time here.
    I tried installing the new installer but I get an error message that the update is not applicable to my computer.  I have Win 7 x64 and I believe I am running the correct file.  Just to make sure, I downloaded and trried to install each of the versions listed, all of which gave back that same error message except one (WindowsServer2003-KB942288-v4-x64.exe) which came back saying that I dont have enought storage space.  I admit my C drive only has 5GB of storage left, but that should be enough.
    Not sure where to go from here.
    *Expert Elite*
    TravisNave
    04-20-2012 11:23 AM in reply to: drblack
    You'll need a considerable amount of space because of temporary install files.  You might move your virtual memory swap file to another hard drive if you have one.  That'll free up some considerable space.  Also delete everything in your %TEMP% folder.
    Travis Nave
    Active Member
    04-20-2012 11:29 AM in reply to: TravisNave
    where do I find the specific temp folder you are describing?
    *Expert Elite*
    TravisNave
    04-20-2012 11:38 AM in reply to: drblack
    It's different on everyone's machine.  In the run box on the Start menu, simply type %TEMP% and hit Enter.  You can safely delete all these files.  There might be gigs of crap in there.  Windows doesn't clean up after itself too well.  Clean it often.  Heck, lots of problems can be resolved simply by cleaning this folder out.  Corrupt files get stuck there and prevent normal things from happening.
    You can safely delete files from any TEMP folder.  Even C:\Windows\Temp.  I recommend it.
    Travis Nave
    Active Member
    04-20-2012 12:22 PM in reply to: drblack
    I deleted everything and have about 6GB free now, but still get the same message.  I tried to install another small program to test installations in general and get the same windows installer error message.
    Now I cannot install or uninstall anything
    *Expert Elite*
    DarrenP
    04-20-2012 12:55 PM in reply to: drblack
    you may have to redo your machine then your windows OS is becoming corrupt
