Installation & Licensing
3ds Max Design 2012 installation problems
4 REPLIES 4
1819 Views, 4 Replies
I am trying to install 3ds Max Design 2012 on a Windows 7 Professional 64bit machine without success. The setup progresses as far as installing the main program and then proceeds to rollback the installation. I have installed the software on another Windows 7 Professional 64bit machine and a Windows XP 64bit machine with success. I have checked for the correct version of .net (version 4) and DirectX, both of which appear correct. I have tried installing in diagnostics mode without success, aswell as installing 3ds max on a different drive from the Windows installation, again a failure. I am running the setup under the local administrator account, in this case 'VYX'. Below is the installation log:
2011/5/27:17:29:14	VYX	V-17	=== Setup started on V-17 by VYX ===
2011/5/27:17:29:14	VYX	V-17	Launch
2011/5/27:17:29:23	VYX	V-17	PageOpen	LaunchDialog
2011/5/27:17:29:52	VYX	V-17	PageOpen	LicenseDialog
2011/5/27:17:29:52	VYX	V-17	PageOpen	ProductSelectionDialog2
2011/5/27:17:30:11	VYX	V-17	PageOpen	LicenseDialog
2011/5/27:17:30:11	VYX	V-17	PageOpen	LaunchDialog
2011/5/27:17:30:24	VYX	V-17	PageOpen	LicenseDialog
2011/5/27:17:31:04	VYX	V-17	PageOpen	ProductInfoDialog
2011/5/27:17:31:07	VYX	V-17	PageOpen	ProductSelectionDialog2
2011/5/27:17:31:28	VYX	V-17	PageOpen	FullProgressDialog
2011/5/27:17:31:28	VYX	V-17	Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2011/5/27:17:32:28	VYX	V-17	Install	DirectX® Runtime	Succeeded
2011/5/27:17:32:28	VYX	V-17	Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/5/27:17:32:35	VYX	V-17	Install	Autodesk Material Library 2012	Succeeded
2011/5/27:17:32:35	VYX	V-17	Installing Autodesk Material Library 2012 - Base Image Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/5/27:17:32:53	VYX	V-17	Install	Autodesk Material Library 2012 - Base Image Library	Succeeded
2011/5/27:17:32:53	VYX	V-17	Installing Autodesk Material Library 2012 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/5/27:17:33:24	VYX	V-17	Install	Autodesk Material Library 2012 - Medium Resolution Library	Succeeded
2011/5/27:17:33:24	VYX	V-17	Installing Autodesk® Backburner 2012: C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2011/5/27:17:33:25	VYX	V-17	Install	Autodesk® Backburner 2012	Succeeded
2011/5/27:17:33:26	VYX	V-17	Installing Autodesk® 3ds Max Design 2012:  TRANSFORMS="C:\Users\VYX\AppData\Local\Temp\_AI9B16.tmp\x64\max\3dsMaxDesign2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" INSTALLDIR="d:\3ds max\3ds Max Design 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/5/27:17:33:43	VYX	V-17	Install	Autodesk® 3ds Max Design 2012	Failed	Installation aborted, Result=1603
2011/5/27:17:33:43	VYX	V-17	Rollback	Autodesk® Backburner 2012	Failed	Installation aborted, Result=1619
2011/5/27:17:33:59	VYX	V-17	Rollback	Autodesk Material Library 2012 - Medium Resolution Library	Succeeded
2011/5/27:17:34:15	VYX	V-17	Rollback	Autodesk Material Library 2012 - Base Image Library	Succeeded
2011/5/27:17:34:33	VYX	V-17	Rollback	Autodesk Material Library 2012	Succeeded
2011/5/27:17:34:33	VYX	V-17	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
 The machine has an installation of 3ds max 2009 and 3ds max 2010 - is it possible for those versions to cause a conflict?
I am running out of ideas here and would appreciate any help you can provide.
V
4 REPLIES 4
TravisNave
Previous installed versions should not cause you problems.  There should be a more detailed installation log in your %temp% folder that may have more insight to your issue.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Here is the file 'MaxDesignInstall.log' compressed.
DarrenP
try running in diagnostics mode: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2893432&linkID=9240617
DarrenP
in reply to: DarrenP
I tried running the installation in diagnostics mode but that did not work.
Administrator Productivity
