• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Accepted Solution
    3ds Max 2013 Licensing freeze issue
    902 Views, 4 Replies
    05-10-2012 03:05 PM
    I have a new computer and installed my student version of 3ds Max 2013, but everytime I try to start it an empty window called Licensing appears, there's no response from it and everything on my computer freezes. I deinstalled and reinstalled it twice, but it's the same problem every time.
    I use the same Windows 7 64-Bit Version I had before and it worked without problems there.
    I hope someone can help me.
    Thanks.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: 3ds Max 2013 Licensing freeze issue
    05-11-2012 09:16 AM in reply to: lalala1309
    Member
    05-11-2012 09:36 AM in reply to: lalala1309
    I solved the problem by downgrading my Internet Explorer to version 8. Nothing else worked.
    Although for some reason a friend who has exact the same system as me had no problem activating it with version 9.
    *Expert Elite*
    TravisNave
    05-11-2012 10:06 AM in reply to: lalala1309
    Strange indeed.  Thanks for posting the fix!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    02-15-2013 03:19 PM in reply to: lalala1309
    Yeah this didnt work for me at all im having same problem and i ve tried every solution on the web nothing works but strangely enough 32bit works perfectly fine ive ran the 64 bit version may many times on this computer before dunno why it doesnt work now.
