Installation & Licensing
3ds Max 2013 Installation Problem
36 REPLIES 36
Message 1 of 37
6714 Views, 36 Replies
I have some problem with installation, and i can't solve it by myself.
This is the issue - I started to install  http://img707.imageshack.us/img707/6905/installation1.jpg and after few seconds it shows this http://img688.imageshack.us/img688/7938/installation2.jpg
I even have nothing to clutch to fix it - none error msg or anything like that :<
Of course I tried to run Setup.exe file as administrator - without any changes.
Please feel free to ask for everything which can help You solve the problem.
Thanks in advance.
Pawel
36 REPLIES 36
Message 21 of 37
leven9leven
in reply to: TravisNave
it failed to install again... i think im hopeless
Message 22 of 37
TravisNave
in reply to: leven9leven
Not necessarily. See if the end of the log fails on the same version.
Autodesk Forums:
Message 23 of 37
leven9leven
ok
Message 24 of 37
leven9leven
the error is still 1603 but its still saying something about net framework
Message 25 of 37
TravisNave
Copy the last part and paste it here. I don't need the whole log. Just
the end.
Autodesk Forums:
Message 26 of 37
leven9leven
2013/4/10:17:47:57 Hi HI-PC === Setup started on HI-PC by Hi ===
2013/4/10:17:47:57 Hi HI-PC Launch
2013/4/10:17:47:58 Hi HI-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/4/10:17:47:58 Hi HI-PC PageOpen LaunchDialog
2013/4/10:17:48:47 Hi HI-PC PageOpen LicenseDialog
2013/4/10:17:48:54 Hi HI-PC PageOpen ProductInfoDialog
2013/4/10:17:48:54 Hi HI-PC PageOpen ProductSelectionDialog2
2013/4/10:17:48:59 Hi HI-PC PageOpen FullProgressDialog
2013/4/10:17:48:59 Hi HI-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/4/10:17:48:59 Hi HI-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/4/10:17:49:49 Hi HI-PC Install .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1603
2013/4/10:17:49:49 Hi HI-PC Download Skipped DOTNET4KB2468871 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/4/10:17:49:49 Hi HI-PC Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x86.exe /q /norestart
2013/4/10:17:50:05 Hi HI-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
Message 27 of 37
TravisNave
Go manually download and install the x86 version from Microsoft.
http://www.microsoft.com/en-us/download/details.aspx?id=3556
Autodesk Forums:
Message 28 of 37
leven9leven
download the 3 files there?
Message 29 of 37
TravisNave
No just the x86 version. Run it. See if it fails.
Autodesk Forums:
Message 30 of 37
leven9leven
k
Message 31 of 37
leven9leven
it says its blocked by something else on my computer
Message 32 of 37
TravisNave
I think you might have found your problem. Is it your personal computer?
Autodesk Forums:
Message 33 of 37
leven9leven
Yep
Message 34 of 37
TravisNave
Make yourself another user account in Control Panel > Users. Make it an
administrator account. Login with it and try again.
Autodesk Forums:
Message 35 of 37
leven9leven
ive got to go right now ill try this tomorrow. ill get to you later! thanks for the help!
Message 36 of 37
leven9leven
I tried a new user and it didnt work... was the new user supposed to have everything uninstalled? because it didnt.
Message 37 of 37
leven9leven
Help again dude? The user thing didnt work
Administrator Productivity
