• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    aztech2100
    Re: 3ds Max 2011 "Software License Checkout Failed Error 20"
    02-22-2012 05:28 PM in reply to: Shad0wforce
    I've tried messing around with the FLEXnet garbage and I can't seem to rid of this "error 20" that keeps popping up. I've tried with FLEXnet enabled, and I've tried with it disabled, either way I still get the error. *Also I no longer have my product code to reinstall max since I'm stupid, so is there a way I can fix this without having to purchase a 2nd copy?*
    Please use plain text.
    TravisNave
    02-24-2012 07:09 AM in reply to: aztech2100
    Make sure you give Everyone full rights to the following folders/files:
    C:\ProgramData\FLEXnet\adskflex_*.data
    C:\ProgramData\FLEXnet\adskflex_*.data.backup
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    Peterga
    05-25-2012 06:41 AM in reply to: Shad0wforce
    Gracia Carlos
    Re: SOLUCION to "Software License Checkout Failed Error 20"
    07-29-2012 10:26 AM in reply to: K4RL02
    I got this error after I tried to install the Adobe CS4 demo, it puts a file in that flex directory which must confuse
    3ds max. Never got the demo running either.
    Member
    08-29-2012 08:02 PM in reply to: Shad0wforce
    Help me, after all install be ok, when i got to run the program, i receive this message :smileyfrustrated:
    Member
    08-29-2012 08:03 PM in reply to: rangel_designer
    PS: ERRO 05!!!!!!
    TravisNave
    09-05-2012 11:12 AM in reply to: rangel_designer
    New Member
    sudhakar
    09-11-2012 12:16 AM in reply to: leaveAlone
    Thanks for the solution.
    It worked for me in 3ds Max 2012. The Flexnet license services were stopped permanently. I just restarted & assigned to Start automatically.
    Thus its working fine now !
    Thanks !!
