Installation & Licensing
New Member
aztech2100
Message 11 of 20 (6,932 Views)
Re: 3ds Max 2011 "Software License Checkout Failed Error 20"
02-22-2012 05:28 PM in reply to: Shad0wforce
I've tried messing around with the FLEXnet garbage and I can't seem to rid of this "error 20" that keeps popping up. I've tried with FLEXnet enabled, and I've tried with it disabled, either way I still get the error. *Also I no longer have my product code to reinstall max since I'm stupid, so is there a way I can fix this without having to purchase a 2nd copy?*
TravisNave
Message 12 of 20 (6,907 Views)
02-24-2012 07:09 AM in reply to: aztech2100
Make sure you give Everyone full rights to the following folders/files:
C:\ProgramData\FLEXnet\adskflex_*.data
C:\ProgramData\FLEXnet\adskflex_*.data.backup
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
Peterga
Message 13 of 20 (5,738 Views)
05-25-2012 06:41 AM in reply to: Shad0wforce
Gracia Carlos
Valued Contributor
hike1
Message 14 of 20 (5,113 Views)
Re: SOLUCION to "Software License Checkout Failed Error 20"
07-29-2012 10:26 AM in reply to: K4RL02
I got this error after I tried to install the Adobe CS4 demo, it puts a file in that flex directory which must confuse
3ds max. Never got the demo running either.
Member
rangel_designer
Message 15 of 20 (4,944 Views)
08-29-2012 08:02 PM in reply to: Shad0wforce
Help me, after all install be ok, when i got to run the program, i receive this message :smileyfrustrated:
Member
rangel_designer
Message 16 of 20 (4,943 Views)
08-29-2012 08:03 PM in reply to: rangel_designer
PS: ERRO 05!!!!!!
TravisNave
Message 17 of 20 (4,893 Views)
09-05-2012 11:12 AM in reply to: rangel_designer
New Member
sudhakar
Message 18 of 20 (4,842 Views)
09-11-2012 12:16 AM in reply to: leaveAlone
Thanks for the solution.
It worked for me in 3ds Max 2012. The Flexnet license services were stopped permanently. I just restarted & assigned to Start automatically.
Thus its working fine now !
Thanks !!
Member
_AKS_
Message 19 of 20 (3,118 Views)
06-02-2013 04:28 AM in reply to: Shad0wforce
Delete "C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data" it will solve the problem
New Member
107348860
Message 20 of 20 (2,333 Views)
10-08-2013 01:15 PM in reply to: _AKS_
I did the same as _AKS_ just said, simply deleting both C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data and C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data_backup.001 and reloading 3ds Max, then when it loads it recreates the files and the server, this was for 3DS Max 2012 though
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
