Solved by pendean. Go to Solution.
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
1. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Select the choice "Download Links".
3. Select your product, then variant, then version as applicable.
4. You should now be presented with the choice to download your software parts (worked fine a few moments ago when I tested it).
I have tried what you recomended but there is only an option for 2012 and up wondering if there is another way to get part 2
thanks for your help.
I listened to your advice, but the selectable downloadble links only vary from 2015 to 2012. I need the PART 2 of 3d Max from the year 2011. Thank you
