Installation & Licensing
3ds Max 2010 fails to start due to biped dlc error
13 REPLIES 13
Message 1 of 14
iyer.kool
11857 Views, 13 Replies
3ds Max 2010 (32bit) fails to start up while loading when it starts to load biped dlc.  Why is this happening and what can be done to set it right?
Tags (1)
13 REPLIES 13
Message 2 of 14
anil_choudhary
in reply to: iyer.kool
Here is the technical solution http://usa.autodesk.com/getdoc/id=TS1071846
Please test resetting the BIPED.INI configuration file.
1. Close 3ds Max Design 2010 / 2011.
2. Browse to the following local user application preferences directory-
Windows VISTA / Windows 7
C:\Users\YOUR_USER_NAME\AppData\Local\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
Windows XP
C:\Documents and Settings\YOUR_USER_NAME\local settings\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
3. Rename the BIPED.INI configuration file in this direcrtory to OLD_BIPED.INI
4. Restart 3ds Max Design 2010, new user application preference file for Biped will be created on startup.
I hope that the above information is useful
Cheers
Anil Choudhary
Product Support Specialist
Autodesk, Inc.
Message 3 of 14
iyer.kool
Hi Anil
Thank you very much for the steps that you suggested to set the biped dlc error right.  By renaming the Biped.Ini file, the problem was resolved and I am now able to use 3Ds Max 2010.  Thanks again.
Regards
Rahul
Message 4 of 14
I am having a very similar problem.
When I try to load 3ds max, it will begin opening plug-ins but get hung up on HSDS.dlm.
Can I use this same method to fix the problem?
Message 5 of 14
Hello Markus,
Try renaming the HSDS.dlm to hsdsdlm_old and see if that helps. You can also copy the hsds.dlm from another working machine and see if that works.
Cheers
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Anil Choudhary
Autodesk, Inc.
Message 6 of 14
Thank you very much! Worked perfectly.
Message 7 of 14
Awsome.
Cheers.
Anil Choudhary
Autodesk, Inc.
Message 8 of 14
thanks .....solved the error :))
Message 9 of 14
femin
 3ds Max 2010 fails to start due to biped dlc error  .there is no boiped .ini. file in that.please help me 😞
Message 10 of 14
roebot01
I am getting this error for 3Ds Max 2016 and doing this does not solve the issue?
I have deleted everything I could see that had these file types and it didn't work, and they would also reappear once I open Max up again.
I can merge the scene into a new empty one though, this does work. but its not ideal with the number of files I have, would like a fix 😄
Message 11 of 14
femin
in reply to: roebot01
Delete the biped.dlc file, restart 3ds max , it will work, 100%
Sent from my iPhone
Message 12 of 14
roebot01
in reply to: femin
It doesn't work, in fact I cant seem to locate this file?
I am defiantly in the right file but all I have that is close to it is:
  • a folder called plugcfg_In (Which doesn't have any Biped named files)
  • ENU-plugcfg-Which has a file called BIPED but the file type is INI
These are the only things I can find close to what you are asking me to delete and I have deleted these to test but still didn't work?
Message 13 of 14
femin
Dear,
Delete that biped. Ini file and try to run max, biped file will automatically generate and the max will work.
Sent from my iPhone
Message 14 of 14
roebot01
in reply to: femin
I already tried but it didn't work
Administrator Productivity
