Installation & Licensing
New Member
iyer.kool
Message 1 of 9 (6,559 Views)
3ds Max 2010 fails to start due to biped dlc error
6559 Views, 8 Replies
02-23-2011 01:08 AM
3ds Max 2010 (32bit) fails to start up while loading when it starts to load biped dlc.  Why is this happening and what can be done to set it right?
Product Support
anil.choudhary
Message 2 of 9 (6,535 Views)
Re: 3ds Max 2010 fails to start due to biped dlc error
02-23-2011 08:42 PM in reply to: iyer.kool
Here is the technical solution http://usa.autodesk.com/getdoc/id=TS1071846
Please test resetting the BIPED.INI configuration file.
1. Close 3ds Max Design 2010 / 2011.
2. Browse to the following local user application preferences directory-
Windows VISTA / Windows 7
C:\Users\YOUR_USER_NAME\AppData\Local\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
Windows XP
C:\Documents and Settings\YOUR_USER_NAME\local settings\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
3. Rename the BIPED.INI configuration file in this direcrtory to OLD_BIPED.INI
4. Restart 3ds Max Design 2010, new user application preference file for Biped will be created on startup.
I hope that the above information is useful
Cheers
Anil Choudhary
Product Support Specialist
New Member
iyer.kool
Message 3 of 9 (6,462 Views)
03-07-2011 09:29 PM in reply to: iyer.kool
Hi Anil
Thank you very much for the steps that you suggested to set the biped dlc error right.  By renaming the Biped.Ini file, the problem was resolved and I am now able to use 3Ds Max 2010.  Thanks again.
Regards
Rahul
New Member
markus_funkus
Message 4 of 9 (5,863 Views)
08-20-2011 08:08 AM in reply to: anil.choudhary
I am having a very similar problem.
When I try to load 3ds max, it will begin opening plug-ins but get hung up on HSDS.dlm.
Can I use this same method to fix the problem?
Product Support
anil.choudhary
Message 5 of 9 (5,848 Views)
08-22-2011 02:27 AM in reply to: markus_funkus
Hello Markus,
Try renaming the HSDS.dlm to hsdsdlm_old and see if that helps. You can also copy the hsds.dlm from another working machine and see if that works.
Cheers
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Anil Choudhary
New Member
markus_funkus
Message 6 of 9 (5,822 Views)
08-24-2011 05:20 PM in reply to: anil.choudhary
Thank you very much! Worked perfectly.
Product Support
anil.choudhary
Message 7 of 9 (5,817 Views)
08-24-2011 05:22 PM in reply to: markus_funkus
Awsome.
Cheers.
Anil Choudhary
New Member
marwanalabhar.web
Message 8 of 9 (5,525 Views)
11-01-2011 05:50 AM in reply to: anil.choudhary
thanks .....solved the error :smileyhappy:)
New Member
femin
Message 9 of 9 (3,811 Views)
12-30-2012 09:00 PM in reply to: iyer.kool
 3ds Max 2010 fails to start due to biped dlc error  .there is no boiped .ini. file in that.please help me :smileysad:
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
