• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    iyer.kool
    3ds Max 2010 fails to start due to biped dlc error
    3642 Views, 8 Replies
    02-23-2011 01:08 AM
    3ds Max 2010 (32bit) fails to start up while loading when it starts to load biped dlc.  Why is this happening and what can be done to set it right?
    Please use plain text.
    Product Support
    Re: 3ds Max 2010 fails to start due to biped dlc error
    02-23-2011 08:42 PM in reply to: iyer.kool
    Here is the technical solution http://usa.autodesk.com/getdoc/id=TS1071846
    Please test resetting the BIPED.INI configuration file.
    1. Close 3ds Max Design 2010 / 2011.
    2. Browse to the following local user application preferences directory-
    Windows VISTA / Windows 7
    C:\Users\YOUR_USER_NAME\AppData\Local\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
    Windows XP
    C:\Documents and Settings\YOUR_USER_NAME\local settings\Autodesk\3dsMaxDesign\2010 - 32bit\enu\plugcfg
    3. Rename the BIPED.INI configuration file in this direcrtory to OLD_BIPED.INI
    4. Restart 3ds Max Design 2010, new user application preference file for Biped will be created on startup.
    I hope that the above information is useful
    Cheers
    Anil Choudhary
    Product Support Specialist
    New Member
    iyer.kool
    03-07-2011 09:29 PM in reply to: iyer.kool
    Hi Anil
    Thank you very much for the steps that you suggested to set the biped dlc error right.  By renaming the Biped.Ini file, the problem was resolved and I am now able to use 3Ds Max 2010.  Thanks again.
    Regards
    Rahul
    New Member
    markus_funkus
    08-20-2011 08:08 AM in reply to: anil.choudhary
    I am having a very similar problem.
    When I try to load 3ds max, it will begin opening plug-ins but get hung up on HSDS.dlm.
    Can I use this same method to fix the problem?
    Product Support
    08-22-2011 02:27 AM in reply to: markus_funkus
    Hello Markus,
    Try renaming the HSDS.dlm to hsdsdlm_old and see if that helps. You can also copy the hsds.dlm from another working machine and see if that works.
    Cheers
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Anil Choudhary
    New Member
    markus_funkus
    08-24-2011 05:20 PM in reply to: anil.choudhary
    Thank you very much! Worked perfectly.
    Product Support
    08-24-2011 05:22 PM in reply to: markus_funkus
    Awsome.
    Cheers.
    Anil Choudhary
    New Member
    marwanalabhar.web
    11-01-2011 05:50 AM in reply to: anil.choudhary
    thanks .....solved the error :smileyhappy:)
    New Member
    12-30-2012 09:00 PM in reply to: iyer.kool
     3ds Max 2010 fails to start due to biped dlc error  .there is no boiped .ini. file in that.please help me :smileysad:
