Installation & Licensing
3ds Max 13 problem with Nitrous and OpenGL
5 REPLIES 5
1454 Views, 5 Replies
Whenever I run 3ds Max with Nitrous, I get 4 blank view ports and I have no idea how to get it to work. I have managed to fix this problem by changing to OpenGL (not DirectX as it causes 3ds to crash). However, whenever I try to run scripts, it requires me to use Nitrous. Is there any way to fix this?
Any help will be greatly appreciated!
Edit: Attached are the screen capped errors
5 REPLIES 5
Anyone?
TravisNave
Is it possible that you just need to update to a certified WHQL video driver, perhaps?
Make sure you are running Update 6, which fixes some Nitrous issues as well.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20652715&linkID=9241178
Autodesk Forums:
in reply to: TravisNave
Thank you I will try it and update if it works!
It's been awhile (only had just recently regained access to my workstation), but I have tried running the patched you linked but the problem still persists
TravisNave
You running the latest WHQL driver from nvidia.com?
Autodesk Forums:
Administrator Productivity
