everything else that comes with it installs fine but Max itself fails , i have tried installing in msconfig mode but still fails
log doc attached
Solved by alison.gangler. Go to Solution.
i also get an error message during instal that backburner did not install but everything continues through
Please locate the install logs in the TEMP directory, accessed by typing '%temp%' in the START > RUN (for Windows OS). You can zip the install logs and attach them. Otherwise, please include a screenshot of the error you are seeing.
Alison
Thanks for uploading the logs. From the Setup.log, it looks like the .NET 3.5 SP1 failed to install. You can browse out to the .NET folder in the Support folder and manually install .NET 3.5.
If the install of this package fails, try to enable the Windows Installer verbose logging:
http://support.microsoft.com/kb/223300
Then when .NET 3.5 SP1 is successfully on the system, you can try the Backburner install also launching it manually or from the setup.exe.
I hope this helps.
-Alison
Thanks that helped.end the end i still had to go insided the autodisk x64 foulder and install from there but its up how
i also face an eror i cannot install the back burner and then everything stops i am attaching the log file
Failure in the installation!!!
I have tried repeatedly to install the free 3ds max 2012 for students, following advice from various forums without success.I need to directly use the program for a school assignment.
(Could you please help me?)
Intallation log file:
2012/4/25: 15:19:31 Alex ALEX-PC === Setup started on ALEX-PC by Alex ===
2012/4/25: 15:19:31 Alex ALEX-PC Launch
2012/4/25: 15:20:08 Alex ALEX-PC === Setup ended ===
2012/4/25: 15:19:33 Alex ALEX-PC === Setup started on ALEX-PC by Alex ===
2012/4/25: 15:19:33 Alex ALEX-PC Launch
2012/4/25: 15:20:09 Alex ALEX-PC PageOpen LaunchDialog
2012/4/25: 15:20:46 Alex ALEX-PC PageOpen BeginDeploymentDialog
2012/4/25: 15:21:14 Alex ALEX-PC PageOpen LaunchDialog
2012/4/25: 15:21:27 Alex ALEX-PC PageOpen LicenseDialog
2012/4/25: 15:21:52 Alex ALEX-PC PageOpen ProductInfoDialog
2012/4/25: 15:23:07 Alex ALEX-PC PageOpen ProductSelectionDialog2
2012/4/25: 15:25:50 Alex ALEX-PC PageOpen FullProgressDialog
2012/4/25: 15:25:50 Alex ALEX-PC Installing DirectX Ā® Runtime: š§ \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \ 3rdParty \ DirectX \ DXSETUP.exe / silent
2012/4/25: 15:26:47 Alex ALEX-PC Install DirectX Ā® Runtime Succeeded
2012/4/25: 15:26:47 Alex ALEX-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT = "D: \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \" FILESINUSETEXT = "" REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:26:56 Alex ALEX-PC Install Autodesk Material Library 2012 Succeeded
2012/4/25: 15:26:56 Alex ALEX-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT = "D: \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \" FILESINUSETEXT = "" REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:27:23 Alex ALEX-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/4/25: 15:27:23 Alex ALEX-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT = "D: \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \" FILESINUSETEXT = "" REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:27:57 Alex ALEX-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/4/25: 15:27:57 Alex ALEX-PC Installing Autodesk Ā® Backburner 2012: š§ \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \ x86 \ Components \ backburner \ BackburnerCIF.exe
2012/4/25: 15:28:12 Alex ALEX-PC Install Autodesk Ā® Backburner 2012 Succeeded
2012/4/25: 15:28:14 Alex ALEX-PC Installing Autodesk Ā® 3ds Max 2012: TRANSFORMS = "C: \ Users \ Alex \ AppData \ Local \ Temp \ _AI6C2A.tmp \ x64 \ max \ 3dsMax2012-standalone. mst "ADSK_EULA_STATUS = # 1 ADSK_SOURCE_ROOT =" š§ \ Autodesk \ Autodesk_3ds_Max_2012_English_Win_32-64bit \ "INSTALLDIR =" d: \ Program Files \ Autodesk \ 3ds Max 2012 \ "FILESINUSETEXT =" "REBOOT = ReallySuppress ADSK_SETUP_EXE = 1
2012/4/25: 15:28:22 Alex ALEX-PC Install Autodesk Ā® 3ds Max 2012 Failed Installation aborted, Result = 1603
2012/4/25: 15:28:22 Alex ALEX-PC Rollback Autodesk Ā® Backburner 2012 Failed Installation aborted, Result = 1619
2012/4/25: 15:28:37 Alex ALEX-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/4/25: 15:28:52 Alex ALEX-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/4/25: 15:29:11 Alex ALEX-PC Rollback Autodesk Material Library 2012 Succeeded
2012/4/25: 15:29:11 Alex ALEX-PC Rollback DirectX Ā® Runtime Failed Failure is ignored, Result = 1619
What moves should I do to accomplish the installation?
Thank you in advance for your help.
