Installation & Licensing
zahn.belag
Message 1 of 13 (2,335 Views)
3Ds Max 2011-2014 freezes on start up the whole PC for 10 minutes - HELP PLEASE!
2335 Views, 12 Replies
06-12-2013 07:12 AM
Hi, like discribed in the Title all newer Versions of 3Ds MAX are Freezing on start for around 5 - 10 minutes and all my other programms with it.
The Problem occures since I reinstalled my Windows (new SSD).
Before everything was fine and I never had a similiar Problem.
The PC is more than powerfull enough (AMD X6/16gb Ram/ 670GTX) and really should'nt be the Problem.
I'm using a Student License.
Things I tried so far without a change:
- installing on SSD and HHD
- installing 2011/2013/2014 and tried x64 as well as the x64 Version
- reinstalling Windows (Ultimate x64) again
My suggestion is that the Problem is connected with the License Check on Start up with the Process FNPLicensingService64.exe.
If you got any idea or hint please let me know because I tried everthing and the problem is really annoying.
(sorry for posting that also in another Forum, but it seems to fit here a lot better)
*Expert Elite*
TravisNave
Message 2 of 13 (2,332 Views)
Re: 3Ds Max 2011-2014 freezes on start up the whole PC for 10 minutes - HELP PLE
06-12-2013 07:45 AM in reply to: zahn.belag
Here's what I typically recommend to start:
1.  Download and install (as a clean install when prompted) an updated WHQL certified video driver for your card.  This can be found here:
http://www.nvidia.com/object/win8-win7-winvista-64bit-320.18-whql-driver.html
2.  Make sure you have local admin rights on your machine.
3.  Make sure UAC is off.  Reboot after changing this setting.
4.  Make anti-virus/firewall exceptions for your Autodesk product.
5.  Clear your %TEMP% folder.
6.  Right-click the icon on the desktop and choose to Disable Digital Signature Icons.  Reboot.
Try it again after these steps.  If it is still slow, yank out your Ethernet cable to disable your network access.  Launch it again.  See if it launches faster offline.  If so, you might have a network issue.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
zahn.belag
Message 3 of 13 (2,319 Views)
06-12-2013 08:40 AM in reply to: TravisNave
Hi, thank you for your help.
I tried everything you mentioned, but it doesent helped. The Icon on the Desktop didn'nt had the point "Disable Digital Signature Icon".
I want to describe the Problem a bit more in detail, maybe that helps.
It does'nt occures always, it's around 70% of the Time.
When I double Click the Icon, the Small 3ds Max Window appears with the Text "Initalizing 3ds MAX..." and freezes for at least two up to five minutes.
After that it's loading the plug ins in around ten seconds.
After that ist says "Starting 3ds Max.." and freezes again for around two Minutes.
Then 3ds max starts with grey Viewports (not initialized?) and freezes again for around two minutes.
After that, the Viewports are ready and I can use it normaly.
Every time it freezes, my complete Pc is frozen and no programm (even Taskmanager) is responding.
Hope that helps to locate the Problem.
*Expert Elite*
DarrenP
Message 4 of 13 (2,316 Views)
06-12-2013 08:51 AM in reply to: zahn.belag
this sounds more like a hardware issue maybe
zahn.belag
Message 5 of 13 (2,314 Views)
06-12-2013 08:57 AM in reply to: DarrenP
I still can use the mouse, but nothing reacts.
What kind of information will help to figure out if its a hardware problem or not?
*Expert Elite*
TravisNave
Message 6 of 13 (2,305 Views)
06-12-2013 09:39 AM in reply to: DarrenP
Agreed, Darren.
*Expert Elite*
DarrenP
Message 7 of 13 (2,304 Views)
06-12-2013 09:40 AM in reply to: TravisNave
i would start with the computer manufactures website to see if they have tools available
zahn.belag
Message 8 of 13 (2,295 Views)
06-12-2013 10:04 AM in reply to: DarrenP
The PC is a Custim Rig, so there is no manufacturer.
Here are some detailed informations about my PC:
Not mentioned is my Samsung 830 Pro SSD, which was the reason for the new Windows in the first place. So maybe it has something to do with it. But I've also installed 3ds Max on my other HDD's which changed nothing.
Spoiler
CPU-Z TXT Report
Binaries
CPU-Z version            1.64.0.x64
Processors
Number of processors        1
Number of threads        6
APICs
Processor 0
    -- Core 0
        -- Thread 0    0
    -- Core 1
        -- Thread 0    1
    -- Core 2
        -- Thread 0    2
    -- Core 3
        -- Thread 0    3
    -- Core 4
        -- Thread 0    4
    -- Core 5
        -- Thread 0    5
Timers
    ACPI timer        3.580 MHz
    HPET timer        14.318 MHz
    Perf timer        3.136 MHz
    Sys timer        1.000 KHz
    BCLK timer        200.67 MHz
Processors Information
Processor 1            ID = 0
    Number of cores        6 (max 6)
    Number of threads    6 (max 6)
    Name            AMD Phenom II X6 1090T
    Codename        Thuban
    Specification        AMD Phenom(tm) II X6 1090T Processor
    Package         Socket AM3 (938)
    CPUID            F.A.0
    Extended CPUID        10.A
    Core Stepping        PH-E0
    Technology        45 nm
    TDP Limit        126 Watts
    Core Speed        1605.3 MHz
    Multiplier x Bus Speed    8.0 x 200.7 MHz
    HT Link speed        2006.7 MHz
    Stock frequency        3200 MHz
    Instructions sets    MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    L1 Data cache        6 x 64 KBytes, 2-way set associative, 64-byte line size
    L1 Instruction cache    6 x 64 KBytes, 2-way set associative, 64-byte line size
    L2 cache        6 x 512 KBytes, 16-way set associative, 64-byte line size
    L3 cache        6 MBytes, 48-way set associative, 64-byte line size
    FID/VID Control        yes
    Min FID            4.0x
    # of P-States        5
    P-State            FID 0x14 - VID 0x06 - IDD 16 (18.00x - 1.475 V)
    P-State            FID 0x10 - VID 0x0C - IDD 16 (16.00x - 1.400 V)
    P-State            FID 0x8 - VID 0x10 - IDD 12 (12.00x - 1.350 V)
    P-State            FID 0x0 - VID 0x14 - IDD 8 (8.00x - 1.300 V)
    P-State            FID 0x100 - VID 0x1A - IDD 5 (4.00x - 1.225 V)
    Package Type        0x1
    Model            09
    String 1        0x0
    String 2        0x1
    Page            0x0
    CmpCap            6
    ApicIdCoreSize        8
    TDC Limit        96 Amps
    Boosted P-States    1
    Max non-turbo ratio    16.00x
    Max turbo ratio        18.00x
    Core Performance Boost    yes
    P-State            1, FID 0x100 - VID 0x1A (4.00x - 1.225 V)
    Attached device        PCI device at bus 0, device 24, function 0
    Attached device        PCI device at bus 0, device 24, function 1
    Attached device        PCI device at bus 0, device 24, function 2
    Attached device        PCI device at bus 0, device 24, function 3
    Attached device        PCI device at bus 0, device 24, function 4
    TSC            3210.6 MHz
    APERF            1605.4 MHz
    MPERF            3210.5 MHz
    PERFEVT            1605.3 MHz
Thread dumps
CPU Thread 0
    APIC ID            0
    Topology        Processor ID 0, Core ID 0, Thread ID 0
    Type            02004010h
    Max CPUID level        00000006h
    Max CPUID ext. level    8000001Bh
    Cache descriptor    Level 1, I, 64 KB, 1 thread(s)
    Cache descriptor    Level 1, D, 64 KB, 1 thread(s)
    Cache descriptor    Level 2, U, 512 KB, 1 thread(s)
    Cache descriptor    Level 3, U, 6 MB, 6 thread(s)
    CPUID
    0x00000000        0x00000006    0x68747541    0x444D4163    0x69746E65
    0x00000001        0x00100FA0    0x00060800    0x00802009    0x178BFBFF
    0x00000002        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000003        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000004        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000005        0x00000040    0x00000040    0x00000003    0x00000000
    0x00000006        0x00000000    0x00000000    0x00000001    0x00000000
    0x80000000        0x8000001B    0x68747541    0x444D4163    0x69746E65
    0x80000001        0x00100FA0    0x10000091    0x000037FF    0xEFD3FBFF
    0x80000002        0x20444D41    0x6E656850    0x74286D6F    0x4920296D
    0x80000003        0x36582049    0x39303120    0x50205430    0x65636F72
    0x80000004        0x726F7373    0x00000000    0x00000000    0x00000000
    0x80000005        0xFF30FF10    0xFF30FF20    0x40020140    0x40020140
    0x80000006        0x20800000    0x42004200    0x02008140    0x0030B140
    0x80000007        0x00000000    0x00000000    0x00000000    0x000003F9
    0x80000008        0x00003030    0x00000000    0x00003005    0x00000000
    0x80000009        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000A        0x00000001    0x00000040    0x00000000    0x0000040F
    0x8000000B        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000C        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000D        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000E        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000F        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000010        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000011        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000012        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000013        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000014        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000015        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000016        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000017        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000018        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000019        0xF0300000    0x60100000    0x00000000    0x00000000
    0x8000001A        0x00000003    0x00000000    0x00000000    0x00000000
    0x8000001B        0x0000001F    0x00000000    0x00000000    0x00000000
    MSR 0x0000001B        0x00000000    0xFEE00900
    MSR 0xC0010114        0x00000000    0x00000008
    MSR 0xC0010061        0x00000000    0x00000030
    MSR 0xC0010062        0x00000000    0x00000002
    MSR 0xC0010063        0x00000000    0x00000003
    MSR 0xC0010064        0x8000019E    0x3C000C14
    MSR 0xC0010065        0x8000019F    0x3C001810
    MSR 0xC0010066        0x80000175    0x3C002008
    MSR 0xC0010067        0x80000154    0x3C002800
    MSR 0xC0010068        0x80000135    0x3C003440
    MSR 0xC0010071        0x01000001    0x3C032800
    MSR 0xC0010015        0x00000000    0x01000010
    MSR 0xC001001F        0x00584000    0x00000008
    MSR 0xC0010058        0x00000000    0xE0000021
    MSR 0xC0010070        0x00000000    0x3C032800
CPU Thread 1
    APIC ID            1
    Topology        Processor ID 0, Core ID 1, Thread ID 0
    Type            02004010h
    CPUID
    0x00000001        0x00100FA0    0x01060800    0x00802009    0x178BFBFF
    MSR 0x0000001B        0x00000000    0xFEE00800
    MSR 0xC0010062        0x00000000    0x00000000
    MSR 0xC0010063        0x00000000    0x00000002
    MSR 0xC0010071        0x01800001    0x3C011810
    MSR 0xC0010071        0x00000001    0x3C043440
    MSR 0xC0010070        0x00000000    0x3C043440
CPU Thread 2
    APIC ID            2
    Topology        Processor ID 0, Core ID 2, Thread ID 0
    Type            02004010h
    CPUID
    0x00000001        0x00100FA0    0x02060800    0x00802009    0x178BFBFF
    MSR 0xC0010071        0x00000001    0x3C032800
CPU Thread 3
    APIC ID            3
    Topology        Processor ID 0, Core ID 3, Thread ID 0
    Type            02004010h
    CPUID
    0x00000001        0x00100FA0    0x03060800    0x00802009    0x178BFBFF
CPU Thread 4
    APIC ID            4
    Topology        Processor ID 0, Core ID 4, Thread ID 0
    Type            02004010h
    CPUID
    0x00000001        0x00100FA0    0x04060800    0x00802009    0x178BFBFF
CPU Thread 5
    APIC ID            5
    Topology        Processor ID 0, Core ID 5, Thread ID 0
    Type            02004010h
    CPUID
    0x00000001        0x00100FA0    0x05060800    0x00802009    0x178BFBFF
Chipset
Northbridge            AMD 870 rev. 00
Southbridge            AMD SB850 rev. 40
Graphic Interface        PCI-Express
PCI-E Link Width        x16
PCI-E Max Link Width        x16
Memory Type            DDR3
Memory Size            16384 MBytes
Channels            Dual, (Unganged)
Memory Frequency        668.9 MHz (3:10)
CAS# latency (CL)        9.0
RAS# to CAS# delay (tRCD)    9
RAS# Precharge (tRP)        9
Cycle Time (tRAS)        24
Bank Cycle Time (tRC)        33
Command Rate (CR)        2T
Uncore Frequency        2006.7 MHz
Memory SPD
DIMM #                1
    SMBus address        0x50
    Memory type        DDR3
    Module format        UDIMM
    Manufacturer (ID)    G.Skill (7F7F7F7FCD000000)
    Size            4096 MBytes
    Max bandwidth        PC3-10700 (667 MHz)
    Part number        F3-10666CL9-4GBRL
    Number of banks        8
    Nominal Voltage        1.50 Volts
    EPP            no
    XMP            no
    AMP            no
JEDEC timings table        CL-tRCD-tRP-tRAS-tRC @ frequency
    JEDEC #1        6.0-6-6-17-23 @ 457 MHz
    JEDEC #2        7.0-7-7-20-27 @ 533 MHz
    JEDEC #3        8.0-8-8-22-30 @ 609 MHz
    JEDEC #4        9.0-9-9-25-34 @ 685 MHz
DIMM #                2
    SMBus address        0x51
    Memory type        DDR3
    Module format        UDIMM
    Size            4096 MBytes
    Number of banks        8
    EPP            no
    XMP            no
    AMP            no
DIMM #                3
    SMBus address        0x52
    Memory type        DDR3
    Module format        UDIMM
    Size            4096 MBytes
    Number of banks        8
    EPP            no
    XMP            no
    AMP            no
DIMM #                4
    SMBus address        0x53
    Memory type        DDR3
    Module format        UDIMM
    Size            4096 MBytes
    Number of banks        8
    EPP            no
    XMP            no
    AMP            no
DIMM #                1
SPD registers
        00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00    92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00
    10    69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05
    20    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
    40    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    50    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    00 00 00 00 00 04 CD 00 00 00 00 00 00 00 2A F0
    80    46 33 2D 31 30 36 36 36 43 4C 39 2D 34 47 42 52
    90    4C 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00
    A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    B0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    C0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM #                2
SPD registers
DIMM #                3
SPD registers
DIMM #                4
SPD registers
Monitoring
Mainboard Model        M4A87TD/USB3 (0x00000315 - 0x5C947A60)
LPCIO
LPCIO Vendor        ITE
LPCIO Model        IT8721
LPCIO Vendor ID        0x90
LPCIO Chip ID        0x8721
LPCIO Revision ID    0x1
Config Mode I/O address    0x2E
Config Mode LDN        0x4
Config Mode registers
    00    00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
    10    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    20    87 21 01 00 00 06 80 00 00 00 00 00 9F 00 00 00
    30    01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60    02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
    70    00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space        LPC, base address = 0x0290
Hardware Monitors
Hardware monitor    ITE IT8721
    Voltage 0    11.68 Volts [0xEA] (+12V)
    Voltage 1    4.87 Volts [0xE8] (+5V)
    Voltage 2    1.26 Volts [0x69] (CPU VCORE)
    Voltage 3    1.67 Volts [0x8B] (VIN3)
    Voltage 4    2.87 Volts [0xEF] (VIN4)
    Voltage 5    3.72 Volts [0xF8] (+3.3V)
    Voltage 6    2.40 Volts [0xC8] (VIN6)
    Voltage 7    0.48 Volts [0x28] (VIN7)
    Voltage 8    1.68 Volts [0x8C] (VIN8)
    Temperature 0    45°C (113°F) [0x2D] (CPU)
    Temperature 1    37°C (98°F) [0x25] (Mainboard)
    Fan 0        650 RPM [0x40F] (CPU)
    Fan PWM 0    0 pc [0x0] (FANPWM0)
    Fan PWM 1    0 pc [0x0] (FANPWM1)
    Fan PWM 2    0 pc [0x0] (FANPWM2)
    00    11 06 F7 03 37 FF 07 37 FF 07 58 0F 07 0F FF FF
    10    C4 0B E7 7F C7 80 00 00 04 FF FF A4 7B 9A 9A 9A
    20    EA E8 63 8A EF F8 C8 28 8C 2D 25 80 80 C0 F1 F1
    30    37 15 20 12 06 2B 92 17 43 44 2C 25 A8 B9 89 9A
    40    E9 FD 1B 0F B5 E4 5F 40 AD 6A D4 00 FF FF FF FF
    50    0F 18 7F 7F 7F 40 56 56 90 56 3D 12 E0 00 00 00
    60    80 14 46 0C A0 41 00 FF 80 00 7F FF 00 41 00 FF
    70    80 00 7F FF 00 41 00 FF FF FF FF FF FF FF FF FF
    80    00 00 00 00 00 00 00 00 00 00 00 00 00 64 02 80
    90    FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
    A0    28 12 12 12 12 12 12 FF FF FF FF FF FF FF FF FF
    B0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    C0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    D0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    E0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    F0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PCI Devices
Description            Host Bridge
Location            bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x5957
    Revision ID        0x00
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Address 3 (memory)    0xE0000000
    Subvendor ID        0x1002
    Subsystem ID        0x5957
    Int. Line        0x00
    Int. Pin        0x00
PCI capability
    Caps class        HyperTransport
    Caps offset        0xC4
    Caps revision        3.00
    Interface type        Slave/Primary
    Link 0 width (in/out)    16 bits/16 bits
    Link 0 frequency    2000 MHz
    Link 1 width (in/out)    8 bits/8 bits
    Link 1 frequency    200 MHz
PCI capability
    Caps offset        0x40
    Interface type        Retry Mode
PCI capability
    Caps offset        0x54
    Interface type        Clumping
PCI capability
    Caps offset        0x9C
    Interface type        Gen3
PCI registers
    00    02 10 57 59 06 00 30 22 00 00 00 06 00 00 00 00
    10    00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 E0
    20    00 00 00 00 00 00 00 00 00 00 00 00 02 10 57 59
    30    00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00
    40    08 54 00 C0 C1 00 00 00 00 00 00 00 42 20 05 00
    50    02 10 57 59 08 9C 00 90 08 10 00 00 00 00 00 00
    60    7D 00 00 00 E3 00 00 00 00 02 20 00 61 4F 00 78
    70    00 00 00 00 00 00 00 00 8C 9D 0F 00 00 00 00 00
    80    00 00 00 00 10 00 00 03 20 01 30 00 31 20 00 40
    90    00 00 00 D0 7D 00 00 00 00 00 00 00 08 00 3C D0
    A0    82 00 00 00 00 00 00 86 00 00 00 00 79 40 00 00
    C0    00 00 00 80 08 40 80 01 20 01 11 11 D0 00 00 00
    D0    60 0B F5 7F 02 00 00 00 00 00 00 00 00 00 00 00
    E0    00 00 05 00 FF FF FF FF 00 00 00 00 00 00 00 00
    F0    00 00 00 00 00 80 80 00 00 00 00 00 00 00 00 00
Description            PCI to PCI Bridge
Location            bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x5978
    Revision ID        0x00
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x01
PCI header
    Primary bus        0x00
    Secondary bus        0x05
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps class        Power Management
    Caps offset        0x50
    Caps version        1.2
PCI capability
    Caps class        PCI Express
    Caps offset        0x58
    Device type        Root Port of PCI-E Root Complex
    Port            0
    Version            2.0
    Physical slot        #0
    Presence detect        yes
    Link width        16x (max 16x)
PCI capability
    Caps class        Message Signalled Interrupts
    Caps offset        0xA0
PCI capability
    Caps class        Subsystem Vendor
    Caps offset        0xB0
    SubVendor ID        0x1002
    SubSystem ID        0x5957
PCI capability
    Caps offset        0xB8
    Interface type        MSI Mapping
Extended capabilities
    Caps class        Vendor Specific
    Caps offset        0x100
    Vendor ID        1
    Size            16
    Caps class        Virtual Channel
    Caps offset        0x110
PCI registers
    00    02 10 78 59 07 05 10 00 00 00 04 06 10 00 01 00
    10    00 00 00 00 00 00 00 00 00 05 05 00 E1 E1 00 20
    20    00 FD 90 FE 01 D6 F1 DF 00 00 00 00 00 00 00 00
    30    00 00 00 00 50 00 00 00 00 00 00 00 00 01 1B 00
    50    01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00
    60    10 09 00 00 02 0D 30 00 41 00 01 71 80 25 14 00
    70    00 00 48 01 08 00 01 00 00 00 00 00 00 00 00 00
    80    00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00
    90    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    A0    05 B0 01 00 0C F0 E3 FE A0 49 00 00 00 00 00 00
    B0    0D B8 00 00 02 10 57 59 08 00 03 A8 00 00 00 00
    E0    50 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
    100    0B 00 01 11 01 00 01 01 00 00 00 00 00 00 00 00
    110    02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
    120    01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00
    130    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x597E
    Revision ID        0x00
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x01
PCI header
    Primary bus        0x00
    Secondary bus        0x04
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
    Caps version        1.2
PCI capability
    Caps offset        0x58
    Port            1
    Version            2.0
    Physical slot        #1
    Presence detect        yes
    Link width        1x (max 2x)
PCI capability
    Caps offset        0xA0
PCI capability
    Caps offset        0xB0
    SubVendor ID        0x1002
    SubSystem ID        0x5957
PCI capability
    Caps offset        0xB8
    Caps offset        0x100
    Vendor ID        1
    Size            16
    Caps offset        0x110
PCI registers
    00    02 10 7E 59 05 05 10 00 00 00 04 06 10 00 01 00
    10    00 00 00 00 00 00 00 00 00 04 04 00 D1 D1 00 20
    20    F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 50 00 00 00 00 00 00 00 00 01 07 00
    60    10 01 00 00 22 0C 30 01 40 00 11 70 80 0C 4C 00
    80    00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00
    A0    05 B0 01 00 0C F0 E3 FE 90 49 00 00 00 00 00 00
    E0    50 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x597F
    Revision ID        0x00
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x01
PCI header
    Primary bus        0x00
    Secondary bus        0x03
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
    Caps version        1.2
PCI capability
    Caps offset        0x58
    Port            2
    Version            2.0
    Physical slot        #1
    Presence detect        yes
PCI capability
    Caps offset        0xA0
PCI capability
    Caps offset        0xB0
    SubVendor ID        0x1002
    SubSystem ID        0x5957
PCI capability
    Caps offset        0xB8
    Caps offset        0x100
    Vendor ID        1
    Size            16
    Caps offset        0x110
PCI registers
    00    02 10 7F 59 06 05 10 00 00 00 04 06 10 00 01 00
    10    00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 20
    20    F0 FC F0 FC F1 FF 01 00 00 00 00 00 00 00 00 00
    60    10 01 00 00 22 0C 30 02 40 00 12 70 80 0C 54 00
    A0    05 B0 01 00 0C F0 E3 FE 80 49 00 00 00 00 00 00
Description            IDE Controller
Location            bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x4390
    Revision ID        0x40
    PI            0x8F
    SubClass        0x01
    BaseClass        0x01
    Cache Line        0x10
    Latency            0x40
    Header            0x00
PCI header
    Address 0 (port)    0x0000B000
    Address 1 (port)    0x0000A000
    Address 2 (port)    0x00009000
    Address 3 (port)    0x00008000
    Address 4 (port)    0x00007000
    Address 5 (memory)    0xFCEFA000
    Subvendor ID        0x1002
    Subsystem ID        0x4390
    Int. Line        0x13
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
PCI capability
    Caps class        0x12
    Caps offset        0x70
PCI capability
    Caps class        0x13
    Caps offset        0xA4
PCI registers
    00    02 10 90 43 07 01 30 02 40 8F 01 01 10 40 00 00
    10    01 B0 00 00 01 A0 00 00 01 90 00 00 01 80 00 00
    20    01 70 00 00 00 A0 EF FC 00 00 00 00 02 10 90 43
    30    00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00
    40    14 80 80 00 01 00 20 00 00 00 80 00 00 00 00 00
    50    05 70 84 00 00 00 00 00 00 00 00 00 00 00 00 00
    60    01 50 22 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    12 A4 10 00 0F 00 00 00 00 00 00 00 00 00 00 00
    80    00 00 00 00 06 1A 14 00 AB 01 08 00 F0 00 00 00
    90    27 60 74 C7 02 43 00 00 08 01 00 00 01 58 11 08
    A0    0C 00 00 00 13 00 06 03 00 00 64 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00
    E0    80 00 00 00 00 00 00 00 00 00 00 00 10 00 00 3F
    F0    00 00 00 00 00 00 00 00 77 77 77 00 00 00 00 00
Description            USB Controller (OHCI)
Location            bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x4397
    Revision ID        0x00
    PI            0x10
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x40
    Header            0x80
PCI header
    Address 0 (memory)    0xFCEF3000
    Subvendor ID        0x1002
    Subsystem ID        0x4397
    Int. Line        0x12
    Int. Pin        0x01
PCI registers
    00    02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00
    10    00 30 EF FC 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 02 10 97 43
    30    00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00
    40    80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00
    50    40 00 00 F0 00 00 00 00 10 F2 FF FF 00 00 00 00
    70    00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
    80    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00
Description            USB 2.0 Controller (EHCI)
Location            bus 0 (0x00), device 18 (0x12), function 2 (0x02)
Common header
    Vendor ID        0x1002
    Model ID        0x4396
    Revision ID        0x00
    PI            0x20
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x40
    Header            0x00
PCI header
    Address 0 (memory)    0xFCEFA400
    Subvendor ID        0x1002
    Subsystem ID        0x4396
    Int. Line        0x11
    Int. Pin        0x02
PCI capability
    Caps offset        0xC0
    Caps version        1.1
PCI capability
    Caps class        Debug Port
    Caps offset        0xE4
PCI registers
    00    02 10 96 43 06 01 B0 02 00 20 03 0C 10 40 00 00
    10    00 A4 EF FC 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 02 10 96 43
    30    00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00
    50    40 21 80 A0 01 00 00 00 00 00 00 00 00 00 00 00
    60    20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00
    A0    01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
    C0    01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00
    E0    00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x4397
    Revision ID        0x00
    PI            0x10
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x40
    Header            0x80
PCI header
    Address 0 (memory)    0xFCEF8000
    Subvendor ID        0x1002
    Subsystem ID        0x4397
    Int. Line        0x12
    Int. Pin        0x01
PCI registers
    10    00 80 EF FC 00 00 00 00 00 00 00 00 00 00 00 00
    50    40 00 00 F0 00 00 00 00 43 FF FF FF 00 00 00 00
zahn.belag
Message 9 of 13 (2,294 Views)
06-12-2013 10:05 AM in reply to: zahn.belag
second Part:
Spoiler
Location            bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
    Vendor ID        0x1002
    Model ID        0x4396
    Revision ID        0x00
    PI            0x20
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x40
    Header            0x00
PCI header
    Address 0 (memory)    0xFCEFA800
    Subvendor ID        0x1002
    Subsystem ID        0x4396
    Int. Line        0x11
    Int. Pin        0x02
PCI capability
    Caps offset        0xC0
    Caps version        1.1
PCI capability
    Caps offset        0xE4
PCI registers
    10    00 A8 EF FC 00 00 00 00 00 00 00 00 00 00 00 00
Description            SMBus Controller
Location            bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x4385
    Revision ID        0x42
    PI            0x00
    SubClass        0x05
    BaseClass        0x0C
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    02 10 85 43 03 04 20 02 42 00 05 0C 00 00 80 00
Location            bus 0 (0x00), device 20 (0x14), function 1 (0x01)
Common header
    Vendor ID        0x1002
    Model ID        0x439C
    Revision ID        0x40
    PI            0x8A
    SubClass        0x01
    BaseClass        0x01
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Address 4 (port)    0x0000FF00
    Subvendor ID        0x1002
    Subsystem ID        0x439C
    Int. Line        0x00
    Int. Pin        0x02
PCI registers
    00    02 10 9C 43 05 00 20 02 40 8A 01 01 00 00 00 00
    10    01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
    20    01 FF 00 00 00 00 00 00 00 00 00 00 02 10 9C 43
    30    00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
    40    06 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00
    60    00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
    70    05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description            Multimedia device
Location            bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
    Vendor ID        0x1002
    Model ID        0x4383
    Revision ID        0x40
    PI            0x00
    SubClass        0x03
    BaseClass        0x04
    Cache Line        0x10
    Latency            0x40
    Header            0x00
PCI header
    Address 0 (memory)    0xFCEF4000
    Subvendor ID        0x1002
    Subsystem ID        0x4383
    Int. Line        0x10
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
    Caps version        1.1
PCI registers
    00    02 10 83 43 06 00 10 04 40 00 03 04 10 40 00 00
    10    04 40 EF FC 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 02 10 83 43
    30    00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
    40    00 00 00 00 01 10 00 00 00 00 00 00 01 00 00 00
    50    01 00 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
    60    00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Description            PCI to ISA Bridge
Location            bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
    Vendor ID        0x1002
    Model ID        0x439D
    Revision ID        0x40
    PI            0x00
    SubClass        0x01
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subvendor ID        0x1002
    Subsystem ID        0x439D
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    02 10 9D 43 0F 00 20 02 40 00 01 06 00 00 80 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 02 10 9D 43
    40    04 00 00 00 55 C0 03 FF 17 FF 40 00 00 00 00 00
    60    00 00 00 00 30 02 00 00 00 00 00 00 F0 FF FF FF
    70    67 45 23 00 00 00 00 00 1C 00 00 00 05 0B 00 00
    80    08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 00 00 00 00 00 00 00 00 00 00 01 10 D6 FE
    A0    02 00 C1 FE 2E 01 00 00 00 00 00 00 00 00 00 00
    B0    00 00 00 00 00 00 00 00 00 00 09 39 00 00 00 00
Location            bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
    Vendor ID        0x1002
    Model ID        0x4384
    Revision ID        0x40
    PI            0x01
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x40
    Header            0x81
PCI header
    Primary bus        0x00
    Secondary bus        0x02
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    02 10 84 43 07 05 A0 02 40 01 04 06 00 40 81 00
    10    00 00 00 00 00 00 00 00 00 02 02 40 F0 00 80 22
    20    F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00
    40    26 00 3C FF 00 00 00 00 0C 0F 3D D1 00 01 00 00
    50    01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF
    60    CA 0E 17 00 BA 98 10 02 00 00 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06
    E0    00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 20 (0x14), function 5 (0x05)
Common header
    Vendor ID        0x1002
    Model ID        0x4399
    Revision ID        0x00
    PI            0x10
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x40
    Header            0x00
PCI header
    Address 0 (memory)    0xFCEF9000
    Subvendor ID        0x1002
    Subsystem ID        0x4399
    Int. Line        0x12
    Int. Pin        0x03
PCI registers
    00    02 10 99 43 16 01 A0 02 00 10 03 0C 10 40 00 00
    10    00 90 EF FC 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 02 10 99 43
    30    00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
    50    40 00 00 F0 00 00 00 00 FF FF FF FF 00 00 00 00
Location            bus 0 (0x00), device 21 (0x15), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x43A0
    Revision ID        0x00
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x81
PCI header
    Primary bus        0x00
    Secondary bus        0x01
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
    Caps version        1.2
PCI capability
    Caps offset        0x58
    Port            0
    Version            2.0
    Physical slot        #4
    Presence detect        yes
    Link width        1x (max 1x)
PCI capability
    Caps offset        0xA0
PCI capability
    Caps offset        0xB0
    SubVendor ID        0x1002
    SubSystem ID        0x0000
PCI capability
    Caps offset        0xB8
    Caps offset        0x100
    Vendor ID        1
    Size            16
PCI registers
    00    02 10 A0 43 07 05 10 00 00 00 04 06 10 00 81 00
    10    00 00 00 00 00 00 00 00 00 01 01 00 C1 C1 00 20
    20    F0 FF 00 00 F1 D5 F1 D5 00 00 00 00 00 00 00 00
    50    01 58 03 06 00 00 00 00 10 A0 42 01 20 80 00 00
    60    10 01 00 00 12 0C 30 00 40 00 11 70 00 05 04 01
    70    00 00 48 01 08 00 01 00 00 00 00 00 1F 00 00 00
    80    06 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00
    A0    05 B0 81 00 0C F0 E3 FE 00 00 00 00 B0 49 00 00
    B0    0D B8 00 00 02 10 00 00 08 00 03 A8 00 00 00 00
    100    0B 00 01 00 01 00 01 01 00 00 00 00 00 00 00 00
    110    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    120    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
    Vendor ID        0x1002
    Model ID        0x4397
    Revision ID        0x00
    PI            0x10
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x40
    Header            0x80
PCI header
    Address 0 (memory)    0xFCEFB000
    Subvendor ID        0x1002
    Subsystem ID        0x4397
    Int. Line        0x12
    Int. Pin        0x01
PCI registers
    10    00 B0 EF FC 00 00 00 00 00 00 00 00 00 00 00 00
    50    40 00 00 F0 00 00 00 00 65 FF FF FF 00 00 00 00
Location            bus 0 (0x00), device 22 (0x16), function 2 (0x02)
Common header
    Vendor ID        0x1002
    Model ID        0x4396
    Revision ID        0x00
    PI            0x20
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x40
    Header            0x00
PCI header
    Address 0 (memory)    0xFCEFAC00
    Subvendor ID        0x1002
    Subsystem ID        0x4396
    Int. Line        0x11
    Int. Pin        0x02
PCI capability
    Caps offset        0xC0
    Caps version        1.1
PCI capability
    Caps offset        0xE4
PCI registers
    10    00 AC EF FC 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
    Vendor ID        0x1022
    Model ID        0x1200
    Revision ID        0x00
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0x00
    Int. Pin        0x00
PCI capability
    Caps offset        0x80
    Caps revision        3.00
    Interface type        Host/Secondary
    Device number        0
PCI registers
    00    22 10 00 12 00 00 10 00 00 00 00 06 00 00 80 00
    30    00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
    40    01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
    50    01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
    60    00 00 05 00 E0 00 00 00 20 A8 4F 00 20 F8 00 00
    80    08 00 01 21 20 20 11 11 60 0B F5 FF 13 00 00 00
    90    92 02 85 84 00 00 00 00 07 00 00 00 0E 00 00 00
Location            bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
    Vendor ID        0x1022
    Model ID        0x1201
    Revision ID        0x00
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    22 10 01 12 00 00 00 00 00 00 00 06 00 00 80 00
    40    03 00 00 00 00 00 2F 04 00 00 00 00 00 00 00 00
    A0    03 00 E0 00 80 FF EF 00 03 00 F0 00 00 FF FF 00
    B0    03 0A 00 00 00 0B 00 00 03 00 D0 00 00 FF DF 00
    C0    13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
    E0    03 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00
    F0    03 30 00 D0 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
    Vendor ID        0x1022
    Model ID        0x1202
    Revision ID        0x00
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    22 10 02 12 00 00 00 00 00 00 00 06 00 00 80 00
    40    01 00 00 00 09 01 00 00 01 02 00 00 09 03 00 00
    60    E0 3C F8 01 E0 3C F8 01 00 00 00 00 00 00 00 00
    70    00 00 00 00 00 00 00 00 06 00 08 0E 28 04 11 18
    80    77 00 00 00 D4 0A 24 00 45 96 16 00 66 B9 B2 01
    90    00 00 01 00 0D 09 50 3F 07 03 00 80 00 00 00 00
    A0    00 02 00 00 00 00 00 00 40 00 00 00 00 00 00 00
    B0    65 1D 81 D8 A5 00 00 00 61 88 01 81 8C EB 7F 00
    D0    70 8F 9F B0 20 F5 0A 0D 20 A0 8F ED FC 80 E2 9A
    E0    E3 82 02 61 D6 40 C6 E9 00 00 C4 EC CB B5 73 98
    F0    00 00 00 80 00 00 00 00 E5 58 A4 7E D0 55 01 00
Location            bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
    Vendor ID        0x1022
    Model ID        0x1203
    Revision ID        0x00
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0x00
    Int. Pin        0x00
PCI capability
    Caps class        Secure Device
    Caps offset        0xF0
PCI registers
    00    22 10 03 12 00 00 10 00 00 00 00 06 00 00 80 00
    30    00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
    40    FF FF FF 3F 5C 00 B0 4A 00 00 00 00 00 00 00 00
    60    00 00 00 00 05 00 4C 4A 00 00 00 10 52 80 01 00
    70    53 11 04 00 11 11 08 00 14 0C 20 00 0F 09 09 00
    80    81 E6 00 E6 E6 41 E6 01 08 00 00 00 00 40 58 00
    90    00 00 00 00 58 58 00 00 40 42 A2 3D 00 00 00 00
    A0    94 08 1A A0 EF 0F 0C 00 00 00 00 28 00 00 00 00
    D0    00 00 00 00 26 0F 81 C8 15 13 1A 03 1A 64 67 00
    E0    00 00 00 00 30 14 C0 1D 19 DF 07 02 00 00 00 00
    F0    0F 00 10 00 00 00 00 00 00 00 00 00 A0 0F 10 00
Location            bus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
    Vendor ID        0x1022
    Model ID        0x1204
    Revision ID        0x00
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    22 10 04 12 00 00 00 00 00 00 00 06 00 00 80 00
    50    00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 00
Description            Ethernet Controller
Location            bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x10EC
    Model ID        0x8168
    Revision ID        0x06
    PI            0x00
    SubClass        0x00
    BaseClass        0x02
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (port)    0x0000C800
    Address 2 (memory)    0xD5FFF000
    Address 4 (memory)    0xD5FF8000
    Subvendor ID        0x1043
    Subsystem ID        0x8432
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x40
    Caps version        1.2
PCI capability
    Caps offset        0x50
PCI capability
    Caps offset        0x70
    Device type        PCI-E Endpoint Device
    Port            0
    Version            2.0
PCI capability
    Caps class        MSI-X
    Caps offset        0xB0
PCI capability
    Caps class        Virtual Product Data
    Caps offset        0xD0
    Caps class        Advanced Error Reporting
    Caps offset        0x100
    Caps offset        0x140
    Caps class        Device Serial Number
    Caps offset        0x160
PCI registers
    00    EC 10 68 81 07 05 10 00 06 00 00 02 10 00 00 00
    10    01 C8 00 00 00 00 00 00 0C F0 FF D5 00 00 00 00
    20    0C 80 FF D5 00 00 00 00 00 00 00 00 43 10 32 84
    30    00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
    40    01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00
    50    05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    10 B0 02 02 C1 8C 28 00 07 50 19 00 11 3C 07 00
    80    40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 00 00 10 00 00 00 10 00 00 00 00 00 00 00
    B0    11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00
    D0    03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    100    01 00 01 14 00 00 10 00 00 00 00 00 30 20 06 00
    110    00 20 00 00 00 00 00 00 B4 00 00 00 01 00 00 04
    120    0F 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00
Location            bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x1033
    Model ID        0x0194
    Revision ID        0x03
    PI            0x30
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0xFCFFA000
    Subvendor ID        0x1043
    Subsystem ID        0x8413
    Int. Line        0x0A
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
    Caps version        1.2
PCI capability
    Caps offset        0x70
PCI capability
    Caps class        MSI-X
    Caps offset        0x90
PCI capability
    Caps offset        0xA0
    Port            0
    Version            2.0
    Caps offset        0x100
    Caps offset        0x140
    Caps class        0x18
    Caps offset        0x150
PCI registers
    00    33 10 94 01 06 01 10 00 03 30 03 0C 10 00 00 00
    10    04 A0 FF FC 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 43 10 13 84
    30    00 00 00 00 50 00 00 00 00 00 00 00 0A 01 00 00
    50    01 70 C3 C9 08 00 00 00 00 00 00 00 00 00 00 00
    60    30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    05 90 86 00 00 00 00 00 00 00 00 00 00 00 00 00
    90    11 A0 07 00 00 10 00 00 80 10 00 00 00 00 00 00
    A0    10 00 02 00 C0 8F 00 00 00 28 19 00 12 EC 07 00
    B0    40 01 12 10 00 00 00 00 00 00 00 00 00 00 00 00
    C0    00 00 00 00 10 08 00 00 00 00 00 00 00 00 00 00
    D0    02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0    FC 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    F0    08 14 60 00 00 00 00 00 00 00 00 00 00 00 00 00
    110    00 20 00 00 00 00 00 00 14 00 00 00 01 00 00 04
    120    0F 01 00 00 00 00 01 03 7B 8E B9 D2 00 00 00 00
Location            bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x197B
    Model ID        0x2368
    Revision ID        0x00
    PI            0x85
    SubClass        0x01
    BaseClass        0x01
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (port)    0x0000DC00
    Address 1 (port)    0x0000D880
    Address 2 (port)    0x0000D800
    Address 3 (port)    0x0000D480
    Address 4 (port)    0x0000D400
    Subvendor ID        0x1043
    Subsystem ID        0x827E
    Int. Line        0x11
    Int. Pin        0x01
PCI capability
    Caps offset        0x68
    Caps version        1.1
PCI capability
    Caps offset        0x50
    Device type        Legacy PCI-E Endpoint Device
    Port            1
    Version            1.0
PCI registers
    00    7B 19 68 23 05 01 10 00 00 85 01 01 10 00 00 00
    10    01 DC 00 00 81 D8 00 00 01 D8 00 00 81 D4 00 00
    20    01 D4 00 00 00 00 00 00 00 00 00 00 43 10 7E 82
    30    00 00 00 00 68 00 00 00 00 00 00 00 11 01 00 00
    40    BD 00 C0 00 08 08 80 F0 00 00 00 00 00 00 00 00
    50    10 00 11 02 00 00 00 00 00 20 08 00 11 44 02 01
    60    40 00 11 10 00 00 00 00 01 50 02 00 00 00 00 00
    80    00 00 00 00 A0 01 00 00 0F 00 00 00 00 00 00 00
    B0    31 00 00 00 00 00 00 08 00 00 00 00 00 00 00 80
    C0    C3 8B 38 70 03 45 02 00 00 00 00 00 00 00 00 00
    D0    18 00 00 80 00 00 00 10 00 00 EB 00 00 00 00 01
    100    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description            VGA Controller
Location            bus 5 (0x05), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x10DE
    Model ID        0x1189
    Revision ID        0xA1
    PI            0x00
    SubClass        0x00
    BaseClass        0x03
    Cache Line        0x10
    Latency            0x00
    Header            0x80
PCI header
    Address 0 (memory)    0xFD000000
    Address 1 (memory)    0xD8000000
    Address 3 (memory)    0xD6000000
    Address 5 (port)    0x0000EC00
    Subvendor ID        0x1569
    Subsystem ID        0x1189
    Int. Line        0x12
    Int. Pin        0x01
PCI capability
    Caps offset        0x60
    Caps version        1.2
PCI capability
    Caps offset        0x68
PCI capability
    Caps offset        0x78
    Port            0
    Version            2.0
PCI capability
    Caps class        Vendor Dependant
    Caps offset        0xB4
    Caps offset        0x100
    Caps class        Power Budgeting
    Caps offset        0x128
    Caps offset        0x600
    Vendor ID        1
    Size            36
PCI registers
    00    DE 10 89 11 07 01 10 00 A1 00 00 03 10 00 80 00
    10    00 00 00 FD 0C 00 00 D8 00 00 00 00 0C 00 00 D6
    20    00 00 00 00 01 EC 00 00 00 00 00 00 69 15 89 11
    30    00 00 00 00 60 00 00 00 00 00 00 00 12 01 00 00
    40    69 15 89 11 00 00 00 00 00 00 00 00 00 00 00 00
    50    01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
    60    01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
    70    00 00 00 00 00 00 00 00 10 B4 02 00 E1 8D 2C 01
    80    00 29 00 00 02 3D 45 00 41 00 01 11 00 00 00 00
    90    00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 00
    A0    00 00 00 00 00 00 00 00 02 00 01 00 00 00 00 00
    B0    00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
    100    02 00 81 12 00 00 00 00 00 00 00 00 00 00 00 00
    110    00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
    120    00 00 00 00 00 00 00 00 04 00 01 60 00 00 00 00
    130    21 81 07 00 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 5 (0x05), device 0 (0x00), function 1 (0x01)
Common header
    Vendor ID        0x10DE
    Model ID        0x0E0A
    Revision ID        0xA1
    PI            0x00
    SubClass        0x03
    BaseClass        0x04
    Cache Line        0x10
    Latency            0x00
    Header            0x80
PCI header
    Address 0 (memory)    0xFE97C000
    Subvendor ID        0x1569
    Subsystem ID        0x1189
    Int. Line        0x13
    Int. Pin        0x02
PCI capability
    Caps offset        0x60
    Caps version        1.2
PCI capability
    Caps offset        0x68
PCI capability
    Caps offset        0x78
    Port            0
    Version            2.0
PCI registers
    00    DE 10 0A 0E 06 01 10 00 A1 00 03 04 10 00 80 00
    10    00 C0 97 FE 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 69 15 89 11
    30    00 00 00 00 60 00 00 00 00 00 00 00 13 02 00 00
    50    00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
    70    00 00 00 00 00 00 00 00 10 00 02 00 E1 8D 2C 01
    80    00 21 00 00 02 3D 45 00 41 00 01 11 00 00 00 00
    A0    00 00 00 00 06 00 00 00 00 00 01 00 00 00 00 00
    100    00 00 00 00 00 00 00 00 00 00 00 00 30 20 46 00
    110    00 20 00 00 00 A0 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
    vendor            American Megatrends Inc.
    version            2001
    date            03/08/2011
    ROM size        1024 KB
DMI System Information
    manufacturer        System manufacturer
    product            System Product Name
    version            System Version
    serial            System Serial Number
    UUID            {B5C7D5A0-0101-11E0-89B5-BCAEC5295D88}
    SKU            To Be Filled By O.E.M.
    family            To Be Filled By O.E.M.
DMI Baseboard
    vendor            ASUSTeK Computer INC.
    model            M4A87TD/USB3
    revision        Rev 1.xx
    serial            108013390000380
DMI System Enclosure
    manufacturer        Chassis Manufacture
    chassis type        Desktop
    chassis serial        Chassis Serial Number
DMI Processor
    manufacturer        AMD
    model            AMD Phenom(tm) II X6 1090T Processor
    clock speed        3200.0 MHz
    FSB speed        200.0 MHz
    multiplier        16.0x
DMI Port Connector
    designation        KB (internal)
    designation        Keyboard (external)
    port type        Keyboard Port
    connector        PS/2
DMI Port Connector
    designation        MS (internal)
    designation        Mouse (external)
    connector        PS/2
DMI Port Connector
    designation        USB1_2 (internal)
    designation        USB1_2 (external)
    port type        USB
    connector        Access Bus (USB)
DMI Port Connector
    designation        USB3_4 (internal)
    designation        USB3_4 (external)
    port type        USB
DMI Port Connector
    designation        USB5_6 (internal)
    designation        USB5_6 (external)
    port type        USB
DMI Port Connector
    designation        USB13_14 (internal)
    designation        USB3_12 (external)
    port type        USB
DMI Port Connector
    designation        GbE LAN1 (internal)
    designation        GbE LAN1 (external)
    port type        Network Port
    connector        RJ-45
DMI Port Connector
    designation        Line In (internal)
    designation        Line In (external)
    port type        Audio Port
    connector        Mini Jack (headphones)
DMI Port Connector
    designation        Line Out (internal)
    designation        Line Out (external)
DMI Port Connector
    designation        Mic In (internal)
    designation        Mic In (external)
DMI Port Connector
    designation        MAIN POWER (internal)
DMI Port Connector
    designation        CPU_FAN (internal)
DMI Port Connector
    designation        PWR_FAN (internal)
DMI Port Connector
    designation        USB07_08 (internal)
    port type        USB
    connector        9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
    designation        USB09_10 (internal)
    port type        USB
DMI Port Connector
    designation        USB11_12 (internal)
    port type        USB
DMI Port Connector
    designation        SATA1 (internal)
DMI Port Connector
    designation        SATA2 (internal)
DMI Port Connector
    designation        SATA3 (internal)
DMI Port Connector
    designation        SATA4 (internal)
DMI Port Connector
    designation        SATA5 (internal)
DMI Port Connector
    designation        SATA6 (internal)
DMI Port Connector
    designation        COM1 (internal)
DMI Port Connector
    designation        AAFP (internal)
DMI Port Connector
    designation        SPDIF_OUT (internal)
DMI Port Connector
    designation        PRI_IDE (internal)
    connector        On Board IDE
DMI Port Connector
    designation        PANEL (internal)
DMI Extension Slot
    designation        PCIEX1_1
    type            A5
    width            32 bits
    populated        yes
DMI Extension Slot
    designation        PCIEX4_1
    type            A5
    width            32 bits
    populated        no
DMI Extension Slot
    designation        PCIEX16_1
    type            A5
    width            32 bits
    populated        yes
DMI Extension Slot
    designation        PCI1
    type            PCI
    width            32 bits
    populated        no
DMI Extension Slot
    designation        PCI2
    type            PCI
    width            32 bits
    populated        no
DMI Extension Slot
    designation        PCI3
    type            PCI
    width            32 bits
    populated        no
DMI OEM Strings
    string[0]        BCAEC5295D88
    string[1]        To Be Filled By O.E.M.
    string[2]        To Be Filled By O.E.M.
    string[3]        To Be Filled By O.E.M.
DMI Physical Memory Array
    location        Motherboard
    usage            System Memory
    correction        None
    max capacity        16384 MBytes
    max# of devices        4
DMI Memory Device
    designation        DIMM0
    format            DIMM
    type            unknown
    total width        64 bits
    data width        64 bits
    size            4096 MBytes
DMI Memory Device
    designation        DIMM1
    format            DIMM
    type            unknown
    total width        64 bits
    data width        64 bits
    size            4096 MBytes
DMI Memory Device
    designation        DIMM2
    format            DIMM
    type            unknown
    total width        64 bits
    data width        64 bits
    size            4096 MBytes
DMI Memory Device
    designation        DIMM3
    format            DIMM
    type            unknown
    total width        64 bits
    data width        64 bits
    size            4096 MBytes
Graphics
Number of adapters        1
Graphic APIs
API                NVIDIA I/O
Display Adapters
Display adapter 0
    Name            NVIDIA GeForce GTX 670
    Revision        A2
    Codename        GK104
    Technology        28 nm
    Memory size        2047 MB
    PCI device        bus 5 (0x5), device 0 (0x0), function 0 (0x0)
    Vendor ID        0x10DE (0x1569)
    Model ID        0x1189 (0x1189)
    Performance Level    0
Win32_VideoController        AdapterRAM = 0x7FFB0000 (2147155968)
Software
Windows Version            Microsoft Windows 7 (6.1) Ultimate Edition 64-bit  Service Pack 1 (Build 7601)
DirectX Version            11.0
zahn.belag
Message 10 of 13 (2,269 Views)
06-13-2013 12:00 AM in reply to: zahn.belag
Hey, I noticed something else, maybe that helps to locate the problem:
Autosave is enabled in 3ds Max and everytime it autosaves it tooks a long time to, like two or three minutes.
So maybe it has something to do with writing permissions or the SSD or something.
Please help if you have any ideas.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
