Hey guys I'm having a problem with the install, here is a log. I'm using the disks, and the entertainment creation disk(for education), 32bit. Attached are my pc specs. Cheers.
2011/11/10:13:47:26 dane DANE-PC === Setup started on DANE-PC by dane === 2011/11/10:13:47:26 dane DANE-PC Launch 2011/11/10:13:49:01 dane DANE-PC === Setup ended === 2011/11/10:13:47:51 dane DANE-PC === Setup started on DANE-PC by dane === 2011/11/10:13:47:51 dane DANE-PC Launch 2011/11/10:13:49:02 dane DANE-PC PageOpen LaunchDialog 2011/11/10:13:52:14 dane DANE-PC PageOpen LicenseDialog 2011/11/10:13:52:22 dane DANE-PC PageOpen ProductInfoDialog 2011/11/10:13:53:09 dane DANE-PC PageOpen ProductSelectionDialog2 2011/11/10:13:53:57 dane DANE-PC PageOpen FullProgressDialog 2011/11/10:13:53:57 dane DANE-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\dane\AppData\Local\Temp\vcredist_x86_2005.log"" " 2011/11/10:13:54:04 dane DANE-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
Similar issue is discussed here
http://forums.autodesk.com/t5/Installation-Licensing/Cannot-install-3D-Studio-Max/td-p/3211272
