I've tried numerous times to install the Student version of Max, both versions 2014 and 2015. I've used all download versions, including virtual assistant.
I'm running on Windows 8.1 professional.
Attached is the log file of my latest installation attempt.
Solved by ukdxb012. Go to Solution.
Hi @elacerna,
Thanks for the installation log! Will you please take the following steps to try and resolve the 1619 error:
Please let me know if this resolves your issue or if you need further assistance. Thank you!
same problem here ! ive tried to install the student version and it seemed to keep failing. My desktop is now running Windows 8.1 64-bit, intel core i7, 16GB RAM . can anyone help me ? the attached is the setup log.
Your issue is related to the Autodesk Medium Material Library. Please install it from here (http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-... and then try 3DS Max again. If you have further issues i would look to download the product as a Browser Download to avoid these kind of issues in future.
Hi @elacerna
3DS Max 2014 is not suppoorted on Windows 8.1 however 2015 is.
The response Jessica provided you should resolve the 1603 issues you are experiencing.
Here is a link which explains a bit more about 1603 errors... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
