Installation & Licensing
3DS Max 2014 Student Version: Error 20 License Error
1 REPLY 1
sunshine8077
1077 Views, 1 Reply
Hey
Been having troube trying to open 3DS MAX 2014 Student Version on my Windows 8.1 laptop. I've looked at other threads from people who have had the same problem, but still not luck. I've tried re-installing and tried the method involving the moving of or renaming of the files in the FLEXnet folder in Program date. Any other possible solutions to this problem?
Harvey
1 REPLY 1
TravisNave
in reply to: sunshine8077
Welcome to the community.  Error 20 has often plagued this software suite.  However, the fact that Windows 8.1 has not technically been deemed supported yet is another issue.  It may be some time before all the bugs are worked out.  I suspect that it will be supported with an update.  Also the 2015 software should also be supported.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
