Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
3DS Max 2013 Failed install "Error getting file security"
- Highlight
- Email to a Friend
This is what im getting when trying to install 2013....also getting it when trying to Uninstall 2012
log file
"2013/1/16:08:21:14 Note NOTE-PC === Setup started on NOTE-PC by Note ===
2013/1/16:08:21:14 Note NOTE-PC Launch
2013/1/16:08:21:18 Note NOTE-PC === Setup ended ===
2013/1/16:08:21:15 Note NOTE-PC === Setup started on NOTE-PC by Note ===
2013/1/16:08:21:15 Note NOTE-PC Launch
2013/1/16:08:21:19 Note NOTE-PC PageOpen LaunchDialog
2013/1/16:08:21:47 Note NOTE-PC PageOpen LicenseDialog
2013/1/16:08:21:50 Note NOTE-PC PageOpen ProductInfoDialog
2013/1/16:08:22:44 Note NOTE-PC PageOpen ProductSelectionDialog2
2013/1/16:08:23:25 Note NOTE-PC PageOpen FullProgressDialog
2013/1/16:08:23:25 Note NOTE-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit
2013/1/16:08:25:12 Note NOTE-PC Install DirectX® Runtime Succeeded
2013/1/16:08:25:12 Note NOTE-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_201
2013/1/16:08:25:36 Note NOTE-PC Install Autodesk Material Library 2013 Succeeded
2013/1/16:08:25:36 Note NOTE-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_201
2013/1/16:08:26:23 Note NOTE-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/1/16:08:26:23 Note NOTE-PC Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_201
2013/1/16:08:27:24 Note NOTE-PC Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/1/16:08:27:25 Note NOTE-PC Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\Note\AppData\Local\Temp\_AI85
2013/1/16:08:29:31 Note NOTE-PC Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2013/1/16:08:29:37 Note NOTE-PC Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2013/1/16:08:29:45 Note NOTE-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/1/16:08:30:20 Note NOTE-PC Rollback Autodesk Material Library 2013 Succeeded
2013/1/16:08:30:20 Note NOTE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Im on windows 7 64bit
Re: 3DS Max 2013 Failed install "Error getting file security"
- Highlight
- Email to a Friend
Seems like a permissions issue. This is usually caused by the following:
1. You don't have local admin Rights. Verify this in the Control Panel.
2. UAC is enabled. Disabled User Access Control and reboot. It is all kinds of problematic.
3. You have some sort of Anti-virus protection software that locks down the Program Files folder, etc.
Once you have eliminated all these, try again.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: 3DS Max 2013 Failed install "Error getting file security"
- Highlight
- Email to a Friend
My account is the only user on this computer and it's set to administrator...also disabled firewall, unplugged cable, and lowered the User Access Control down to nothing, and disabled avast antivirus. Same error occurs...I can't seem to uninstall, repair, or reinstall 3ds max 2012 either.
- Highlight
- Email to a Friend
I would check your folder security settings for the ProgramData folder then. Clearly it is a permissions issue caused by policy, virus, or some other unknown reason.
