Hi. I try to install this program a lot of times and always fails. I tried first normally, and then in Safe Mode and I always get errors. I don't know what to do now...
In the log file i have deleted some installations with the same error.
You'll need to attach the bigger installation log in your %temp% location. It will have more information that can help locate the problem.
Can you tell me the name of this .log files? I have a lot of them...
Edit: I think i have found it.
Note: My OS Language is spanish
I think all problems are becouse of a deficient framework 4.
When i install it, all problems appeared. (i have to use a framework cleanup tool to delete it)
I donwload the full installer from the Microsoft site, but it's the same.
Framework 4 is the problem.
Hi and thanks for reply.
I have unistalled all frameWork, but when I try to install, the 3DS Max Installer install FrameWork 4. And it fail again...
I know, same thing happen with all the Autodesk Suite 2012 that use Framework 4.0.
My friend have Revit 2012, and the same problem.
But is not a problem of the Autodesk program, is a bug on the Framework 4.0.
I download it from Microsoft site, and it have the same problem... stil waiting for the hotfix...
I have found a "solution" (I have installed it and it works). I have seen that it is a security problem. The installer can't write (i don't know) in the windows folders. To solve it I have Unhide and give right to everybody to "?:\Users\User Name\AppData". Doing this I can install
