• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Comanderblack
    3DS Max 2012 fails to install
    2328 Views, 7 Replies
    05-16-2011 01:16 AM
    Hi. I try to install this program a lot of times and always fails. I tried first normally, and then in Safe Mode and I always get errors. I don't know what to do now...
    In the log file i have deleted some installations with the same error.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: 3DS Max 2012 fails to install
    05-16-2011 07:55 AM in reply to: Comanderblack
    You'll need to attach the bigger installation log in your %temp% location.  It will have more information that can help locate the problem.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    Comanderblack
    05-16-2011 08:10 AM in reply to: TravisNave
    Can you tell me the name of this .log files? I have a lot of them...
    Edit: I think i have found it.
    Note: My OS Language is spanish
    Member
    Comanderblack
    05-28-2011 05:06 AM in reply to: Comanderblack
    Nobody can help me? I don't know what to do...
    Member
    emi_100
    05-29-2011 08:41 AM in reply to: Comanderblack
    I think all problems are becouse of a deficient framework 4.
    When i install it, all problems appeared. (i have to use a framework cleanup tool to delete it)
    I donwload the full installer from the Microsoft site, but it's the same.
    Framework 4 is the problem.
    Member
    Comanderblack
    05-29-2011 01:32 PM in reply to: emi_100
    Hi and thanks for reply.
    I have unistalled all frameWork, but when I try to install, the 3DS Max Installer install FrameWork 4. And it fail again...
    Member
    emi_100
    05-29-2011 01:37 PM in reply to: Comanderblack
    I know, same thing happen with all the Autodesk Suite 2012 that use Framework 4.0.
    My friend have Revit 2012, and the same problem.
    But is not a problem of the Autodesk program, is a bug on the Framework 4.0.
    I download it from Microsoft site, and it have the same problem... stil waiting for the hotfix...
    Member
    Comanderblack
    06-24-2011 09:19 AM in reply to: emi_100
    I have found a "solution" (I have installed it and it works). I have seen that it is a security problem. The installer can't write (i don't know) in the windows folders. To solve it I have Unhide and give right to everybody to "?:\Users\User Name\AppData". Doing this I can install
