Installation & Licensing
3DS Max 2012 failed to install + log
1 REPLY 1
638 Views, 1 Reply
I just bought my new 3ds maz 2012
I went to install and it said
" Installation complete. Some products failed to install"
Failed = Autodesk 3ds Max 2012
3dsMax Composite 2012
this is my installation log
2012/5/23:20:25:09 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:20:25:09 Minecraft POOM-PC Launch
2012/5/23:20:26:44 Minecraft POOM-PC === Setup ended ===
2012/5/23:20:25:10 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:20:25:10 Minecraft POOM-PC Launch
2012/5/23:20:26:44 Minecraft POOM-PC PageOpen LaunchDialog
2012/5/23:20:27:12 Minecraft POOM-PC PageOpen LicenseDialog
2012/5/23:20:27:17 Minecraft POOM-PC PageOpen ProductInfoDialog
2012/5/23:20:27:52 Minecraft POOM-PC PageOpen ProductSelectionDialog2
2012/5/23:20:28:31 Minecraft POOM-PC PageOpen FullProgressDialog
2012/5/23:20:28:32 Minecraft POOM-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): E:\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Minecraft\AppData\Local\Temp\vcredist_x64_2005.log"" "
2012/5/23:20:28:44 Minecraft POOM-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2012/5/23:20:28:44 Minecraft POOM-PC Installing .NET Framework Runtime 3.5 SP1: E:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2012/5/23:20:29:09 Minecraft POOM-PC Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2012/5/23:20:29:09 Minecraft POOM-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/23:20:31:12 Minecraft POOM-PC Install DirectX® Runtime Succeeded
2012/5/23:20:31:12 Minecraft POOM-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIC27A.tmp\Media.mst"
2012/5/23:20:31:22 Minecraft POOM-PC Install Autodesk Material Library 2012 Succeeded
2012/5/23:20:31:22 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIC27A.tmp\Media.mst"
2012/5/23:20:31:55 Minecraft POOM-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:20:31:55 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIC27A.tmp\Media.mst"
2012/5/23:20:32:49 Minecraft POOM-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:20:32:49 Minecraft POOM-PC Installing Autodesk® Backburner 2012: E:\x86\Components\backburner\BackburnerCIF.exe
2012/5/23:20:33:02 Minecraft POOM-PC Install Autodesk® Backburner 2012 Succeeded
2012/5/23:20:33:02 Minecraft POOM-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIC27A.tmp\x64\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/23:20:33:10 Minecraft POOM-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2012/5/23:20:33:10 Minecraft POOM-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2012/5/23:20:33:26 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:20:33:44 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:20:34:05 Minecraft POOM-PC Rollback Autodesk Material Library 2012 Succeeded
2012/5/23:20:34:05 Minecraft POOM-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/5/23:20:34:05 Minecraft POOM-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2012/5/23:20:34:06 Minecraft POOM-PC PageOpen InstallCompleteDialog
2012/5/23:20:35:04 Minecraft POOM-PC === Setup ended ===
2012/5/23:20:35:11 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:20:35:11 Minecraft POOM-PC Launch
2012/5/23:20:35:27 Minecraft POOM-PC === Setup ended ===
2012/5/23:20:35:12 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:20:35:12 Minecraft POOM-PC Launch
2012/5/23:20:35:27 Minecraft POOM-PC PageOpen LaunchDialog
2012/5/23:20:35:39 Minecraft POOM-PC PageOpen LicenseDialog
2012/5/23:20:35:42 Minecraft POOM-PC PageOpen ProductInfoDialog
2012/5/23:20:35:58 Minecraft POOM-PC PageOpen ProductSelectionDialog2
2012/5/23:20:36:05 Minecraft POOM-PC PageOpen FullProgressDialog
2012/5/23:20:36:06 Minecraft POOM-PC Installing .NET Framework Runtime 3.5 SP1: E:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2012/5/23:20:36:14 Minecraft POOM-PC Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2012/5/23:20:36:14 Minecraft POOM-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/23:20:37:26 Minecraft POOM-PC Install DirectX® Runtime Succeeded
2012/5/23:20:37:26 Minecraft POOM-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIF56C.tmp\Media.mst"
2012/5/23:20:37:41 Minecraft POOM-PC Install Autodesk Material Library 2012 Succeeded
2012/5/23:20:37:41 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIF56C.tmp\Media.mst"
2012/5/23:20:38:02 Minecraft POOM-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:20:38:03 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIF56C.tmp\Media.mst"
2012/5/23:20:38:29 Minecraft POOM-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:20:38:29 Minecraft POOM-PC Installing Autodesk® Backburner 2012: E:\x86\Components\backburner\BackburnerCIF.exe
2012/5/23:20:38:29 Minecraft POOM-PC Install Autodesk® Backburner 2012 Succeeded
2012/5/23:20:38:30 Minecraft POOM-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AIF56C.tmp\x64\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/23:20:38:37 Minecraft POOM-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2012/5/23:20:38:37 Minecraft POOM-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2012/5/23:20:38:50 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:20:39:05 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:20:39:22 Minecraft POOM-PC Rollback Autodesk Material Library 2012 Succeeded
2012/5/23:20:39:22 Minecraft POOM-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/5/23:20:39:22 Minecraft POOM-PC PageOpen InstallCompleteDialog
2012/5/23:20:49:50 Minecraft POOM-PC === Setup ended ===
2012/5/23:20:49:55 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:20:49:55 Minecraft POOM-PC Launch
2012/5/23:20:50:08 Minecraft POOM-PC === Setup ended ===
2012/5/23:20:50:08 Minecraft POOM-PC PageOpen LaunchDialog
2012/5/23:20:50:21 Minecraft POOM-PC PageOpen LicenseDialog
2012/5/23:20:50:25 Minecraft POOM-PC PageOpen ProductInfoDialog
2012/5/23:20:55:14 Minecraft POOM-PC PageOpen ProductSelectionDialog2
2012/5/23:20:55:17 Minecraft POOM-PC PageOpen FullProgressDialog
2012/5/23:20:55:18 Minecraft POOM-PC Installing .NET Framework Runtime 3.5 SP1: E:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2012/5/23:20:55:26 Minecraft POOM-PC Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2012/5/23:20:55:26 Minecraft POOM-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/23:20:56:36 Minecraft POOM-PC Install DirectX® Runtime Succeeded
2012/5/23:20:56:37 Minecraft POOM-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI6EC0.tmp\Media.mst"
2012/5/23:20:56:47 Minecraft POOM-PC Install Autodesk Material Library 2012 Succeeded
2012/5/23:20:56:47 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI6EC0.tmp\Media.mst"
2012/5/23:20:57:02 Minecraft POOM-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:20:57:02 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI6EC0.tmp\Media.mst"
2012/5/23:20:57:27 Minecraft POOM-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:20:57:27 Minecraft POOM-PC Installing Autodesk® Backburner 2012: E:\x86\Components\backburner\BackburnerCIF.exe
2012/5/23:20:57:27 Minecraft POOM-PC Install Autodesk® Backburner 2012 Succeeded
2012/5/23:20:57:27 Minecraft POOM-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI6EC0.tmp\x64\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/23:20:57:34 Minecraft POOM-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2012/5/23:20:57:34 Minecraft POOM-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2012/5/23:20:57:46 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:20:58:00 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:20:58:18 Minecraft POOM-PC Rollback Autodesk Material Library 2012 Succeeded
2012/5/23:20:58:18 Minecraft POOM-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/5/23:20:58:19 Minecraft POOM-PC PageOpen InstallCompleteDialog
2012/5/23:20:58:50 Minecraft POOM-PC === Setup ended ===
2012/5/23:20:59:29 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:20:59:29 Minecraft POOM-PC Launch
2012/5/23:20:59:43 Minecraft POOM-PC === Setup ended ===
2012/5/23:20:59:43 Minecraft POOM-PC PageOpen LaunchDialog
2012/5/23:20:59:56 Minecraft POOM-PC PageOpen LicenseDialog
2012/5/23:21:00:00 Minecraft POOM-PC PageOpen ProductInfoDialog
2012/5/23:21:00:29 Minecraft POOM-PC PageOpen ProductSelectionDialog2
2012/5/23:21:00:50 Minecraft POOM-PC PageOpen FullProgressDialog
2012/5/23:21:00:50 Minecraft POOM-PC Installing .NET Framework Runtime 3.5 SP1: E:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2012/5/23:21:00:57 Minecraft POOM-PC Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2012/5/23:21:00:57 Minecraft POOM-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/23:21:01:59 Minecraft POOM-PC Install DirectX® Runtime Succeeded
2012/5/23:21:01:59 Minecraft POOM-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3182.tmp\Media.mst"
2012/5/23:21:02:10 Minecraft POOM-PC Install Autodesk Material Library 2012 Succeeded
2012/5/23:21:02:10 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3182.tmp\Media.mst"
2012/5/23:21:02:22 Minecraft POOM-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:21:02:22 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3182.tmp\Media.mst"
2012/5/23:21:02:44 Minecraft POOM-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:21:02:44 Minecraft POOM-PC Installing Autodesk® Backburner 2012: E:\x86\Components\backburner\BackburnerCIF.exe
2012/5/23:21:02:44 Minecraft POOM-PC Install Autodesk® Backburner 2012 Succeeded
2012/5/23:21:02:44 Minecraft POOM-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3182.tmp\x64\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/23:21:02:51 Minecraft POOM-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2012/5/23:21:02:51 Minecraft POOM-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2012/5/23:21:03:03 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:21:03:17 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:21:03:33 Minecraft POOM-PC Rollback Autodesk Material Library 2012 Succeeded
2012/5/23:21:03:34 Minecraft POOM-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/5/23:21:03:34 Minecraft POOM-PC PageOpen InstallCompleteDialog
2012/5/23:21:03:59 Minecraft POOM-PC === Setup ended ===
2012/5/23:21:32:03 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:21:32:03 Minecraft POOM-PC Launch
2012/5/23:21:32:43 Minecraft POOM-PC === Setup ended ===
2012/5/23:21:32:04 Minecraft POOM-PC === Setup started on POOM-PC by Minecraft ===
2012/5/23:21:32:04 Minecraft POOM-PC Launch
2012/5/23:21:32:42 Minecraft POOM-PC PageOpen LaunchDialog
2012/5/23:21:32:55 Minecraft POOM-PC PageOpen LicenseDialog
2012/5/23:21:32:59 Minecraft POOM-PC PageOpen ProductInfoDialog
2012/5/23:21:33:10 Minecraft POOM-PC PageOpen ProductSelectionDialog2
2012/5/23:21:33:12 Minecraft POOM-PC PageOpen FullProgressDialog
2012/5/23:21:33:13 Minecraft POOM-PC Installing .NET Framework Runtime 3.5 SP1: E:\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2012/5/23:21:33:26 Minecraft POOM-PC Install .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1603
2012/5/23:21:33:26 Minecraft POOM-PC Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/23:21:34:59 Minecraft POOM-PC Install DirectX® Runtime Succeeded
2012/5/23:21:35:01 Minecraft POOM-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3BF.tmp\Media.mst"
2012/5/23:21:35:13 Minecraft POOM-PC Install Autodesk Material Library 2012 Succeeded
2012/5/23:21:35:13 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3BF.tmp\Media.mst"
2012/5/23:21:35:31 Minecraft POOM-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:21:35:32 Minecraft POOM-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3BF.tmp\Media.mst"
2012/5/23:21:36:19 Minecraft POOM-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:21:36:19 Minecraft POOM-PC Installing Autodesk® Backburner 2012: E:\x86\Components\backburner\BackburnerCIF.exe
2012/5/23:21:36:20 Minecraft POOM-PC Install Autodesk® Backburner 2012 Succeeded
2012/5/23:21:36:20 Minecraft POOM-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\Minecraft\AppData\Local\Temp\_AI3BF.tmp\x64\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/23:21:36:29 Minecraft POOM-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2012/5/23:21:36:29 Minecraft POOM-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2012/5/23:21:36:46 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2012/5/23:21:36:59 Minecraft POOM-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2012/5/23:21:37:17 Minecraft POOM-PC Rollback Autodesk Material Library 2012 Succeeded
2012/5/23:21:37:17 Minecraft POOM-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
(Minecraft is my profile name)
1 REPLY 1
please answer me. I really need help! i have to do my homework with this!
Administrator Productivity
