So, I have tried the work-arounds proposed by the professionals here on the site. I have remove prerequisites and made sure errors were ignored. I'm starting to lose faith in Autodesk. I am astonished they made a product that will not instal properly that costs quite a bit of money. I'm glad mine is only the educational version.
Installation Log:
2014/5/8:19:03:58 SPEKTRE SPEKTRE-PC === Setup ended ===
2014/5/8:19:02:06 SPEKTRE SPEKTRE-PC === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:02:06 SPEKTRE SPEKTRE-PC Launch
2014/5/8:19:04:00 SPEKTRE SPEKTRE-PC PageOpen LaunchDialog
2014/5/8:19:04:22 SPEKTRE SPEKTRE-PC PageOpen LicenseDialog
2014/5/8:19:04:27 SPEKTRE SPEKTRE-PC PageOpen ProductInfoDialog
2014/5/8:19:04:48 SPEKTRE SPEKTRE-PC PageOpen ProductSelectionDialog2
2014/5/8:19:04:51 SPEKTRE SPEKTRE-PC PageOpen FullProgressDialog
2014/5/8:19:04:52 SPEKTRE SPEKTRE-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\SPEKTRE\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/8:19:05:15 SPEKTRE SPEKTRE-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/5/8:19:05:15 SPEKTRE SPEKTRE-PC PageOpen InstallCompleteDialog
2014/5/8:19:12:35 SPEKTRE SPEKTRE-PC === Setup ended ===
2014/5/8:19:24:34 SPEKTRE SPEKTRE-PC === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:24:34 SPEKTRE SPEKTRE-PC Launch
2014/5/8:19:24:46 SPEKTRE SPEKTRE-PC === Setup ended ===
2014/5/8:19:32:24 SPEKTRE SPEKTRE-PC === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:32:24 SPEKTRE SPEKTRE-PC Launch
2014/5/8:19:32:40 SPEKTRE SPEKTRE-PC === Setup ended ===
2014/5/8:19:32:25 SPEKTRE SPEKTRE-PC === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:32:25 SPEKTRE SPEKTRE-PC Launch
2014/5/8:19:32:40 SPEKTRE SPEKTRE-PC PageOpen LaunchDialog
2014/5/8:19:32:57 SPEKTRE SPEKTRE-PC PageOpen LicenseDialog
2014/5/8:19:33:00 SPEKTRE SPEKTRE-PC PageOpen ProductInfoDialog
2014/5/8:19:33:18 SPEKTRE SPEKTRE-PC PageOpen ProductSelectionDialog2
2014/5/8:19:33:38 SPEKTRE SPEKTRE-PC PageOpen FullProgressDialog
2014/5/8:19:33:38 SPEKTRE SPEKTRE-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2014/5/8:19:34:01 SPEKTRE SPEKTRE-PC Install .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1603
2014/5/8:19:34:01 SPEKTRE SPEKTRE-PC Installing DirectX® Runtime: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2014/5/8:19:36:12 SPEKTRE SPEKTRE-PC Install DirectX® Runtime Succeeded
2014/5/8:19:36:12 SPEKTRE SPEKTRE-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2014/5/8:19:36:15 SPEKTRE SPEKTRE-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/5/8:19:36:15 SPEKTRE SPEKTRE-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:36:34 SPEKTRE SPEKTRE-PC Install Autodesk Material Library 2012 Succeeded
2014/5/8:19:36:34 SPEKTRE SPEKTRE-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:37:12 SPEKTRE SPEKTRE-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2014/5/8:19:37:12 SPEKTRE SPEKTRE-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:38:39 SPEKTRE SPEKTRE-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2014/5/8:19:38:39 SPEKTRE SPEKTRE-PC Installing Autodesk® Backburner 2012: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2014/5/8:19:38:54 SPEKTRE SPEKTRE-PC Install Autodesk® Backburner 2012 Succeeded
2014/5/8:19:38:56 SPEKTRE SPEKTRE-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\SPEKTRE\AppData\Local\Temp\_AI1229.tmp\x86\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:41:57 SPEKTRE SPEKTRE-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2014/5/8:19:41:57 SPEKTRE SPEKTRE-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2014/5/8:19:42:31 SPEKTRE SPEKTRE-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2014/5/8:19:42:50 SPEKTRE SPEKTRE-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2014/5/8:19:43:25 SPEKTRE SPEKTRE-PC Rollback Autodesk Material Library 2012 Succeeded
2014/5/8:19:43:25 SPEKTRE SPEKTRE-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/5/8:19:43:25 SPEKTRE SPEKTRE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/5/8:19:43:26 SPEKTRE SPEKTRE-PC PageOpen InstallCompleteDialog
2014/5/8:19:44:06 SPEKTRE SPEKTRE-PC === Setup ended ===
2014/5/8:19:47:44 SPEKTRE SPEKTRE-PC === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:47:44 SPEKTRE SPEKTRE-PC Launch
2014/5/8:19:48:03 SPEKTRE SPEKTRE-PC === Setup ended ===
2014/5/8:19:47:45 SPEKTRE SPEKTRE-PC === Setup started on SPEKTRE-PC by SPEKTRE ===
2014/5/8:19:47:45 SPEKTRE SPEKTRE-PC Launch
2014/5/8:19:48:03 SPEKTRE SPEKTRE-PC PageOpen LaunchDialog
2014/5/8:19:48:19 SPEKTRE SPEKTRE-PC PageOpen LicenseDialog
2014/5/8:19:48:22 SPEKTRE SPEKTRE-PC PageOpen ProductInfoDialog
2014/5/8:19:48:44 SPEKTRE SPEKTRE-PC PageOpen ProductSelectionDialog2
2014/5/8:19:48:46 SPEKTRE SPEKTRE-PC PageOpen FullProgressDialog
2014/5/8:19:48:46 SPEKTRE SPEKTRE-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2014/5/8:19:49:02 SPEKTRE SPEKTRE-PC Install .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1603
2014/5/8:19:49:02 SPEKTRE SPEKTRE-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:49:15 SPEKTRE SPEKTRE-PC Install Autodesk Material Library 2012 Succeeded
2014/5/8:19:49:15 SPEKTRE SPEKTRE-PC Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:49:39 SPEKTRE SPEKTRE-PC Install Autodesk Material Library 2012 - Base Image Library Succeeded
2014/5/8:19:49:39 SPEKTRE SPEKTRE-PC Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:50:28 SPEKTRE SPEKTRE-PC Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2014/5/8:19:50:28 SPEKTRE SPEKTRE-PC Installing Autodesk® Backburner 2012: C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2014/5/8:19:50:28 SPEKTRE SPEKTRE-PC Install Autodesk® Backburner 2012 Succeeded
2014/5/8:19:50:28 SPEKTRE SPEKTRE-PC Installing Autodesk® 3ds Max 2012: TRANSFORMS="C:\Users\SPEKTRE\AppData\Local\Temp\_AI1B3E.tmp\x86\max\3dsMax2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\3ds Max 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/8:19:59:05 SPEKTRE SPEKTRE-PC Install Autodesk® 3ds Max 2012 Failed Installation aborted, Result=1603
2014/5/8:19:59:05 SPEKTRE SPEKTRE-PC Rollback Autodesk® Backburner 2012 Failed Installation aborted, Result=1619
2014/5/8:19:59:30 SPEKTRE SPEKTRE-PC Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2014/5/8:19:59:49 SPEKTRE SPEKTRE-PC Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2014/5/8:20:00:20 SPEKTRE SPEKTRE-PC Rollback Autodesk Material Library 2012 Succeeded
I now have a 'NEW' error for you to look at. Please see the attached screen capture image.
Disable your antivirus and make sure you have admin rights on your machine.
Also, do NOT install with a service pack. Choose not to:
http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-Suite-failed-installation-aborted-...
Good Luck!
Not immediately obvious to me - what are your system specs and OS version?
There is no option to deselect a service pack however I am not running my Anti-Virus and I am installing now 'Run as Admin'.
