• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    3DMax issue
    164 Views, 2 Replies
    08-21-2012 04:45 AM
    Dear Support,
    We have Autodesk3DMax  2009 software. I have installed this software on my system. When I access this software after few min I am getting an error message "
    An invalid normal array occured. The program will terminate ( index= 65550)
    and it automatically closed the software and opened files too..
    Thank you,
    Graphinet
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: 3DMax issue
    08-21-2012 08:22 AM in reply to: graphadmin
    You might have better luck in the Area forum for 3DS Max.
    http://area.autodesk.com/forum/autodesk-3ds-max/
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    Re: 3DMax issue
    08-22-2012 02:46 AM in reply to: graphadmin
    No luck :smileysad:
