I get this error message when starting 3D Studio Max 2012 64bit.
The 32bit version works fine.
I have searched the internet for a solution and seen suggestions to re-install the latest display driver (seems to be the official Autodesk response), run as an administrator, remove and re-install 3D Studio Max and also to install the Direct X SDK.
I have tried all these solutions and none have worked.
Help!
Windows 64bit Professional
Dual Intel Xeon E5507
12GB RAM
Nvidia Quadro 4000
I have been having the same problem. It started with a missing dll though.
Please try
Thanks for the reply. I had solved the problem already, but I will keep the link for further reference.
Could you please share the solution, if you have some time. thank you.
