Hi there !
I Have a big problem: I canĀ“t install 3DMax it always appears error 1619 and 1603
I run as administrator but it does not work, the error appears all the time!
My Pc have windows 7 and 3G RAM.
Could someone help me please!
Best regards,
Angela
Solved by a41635. Go to Solution.
Error 1619 and 1603 happens because a problem with java and windows installer
This issue is to Uninstalling java ( if you canĀ“t Uninstall, Uniinstall in safe mode)
Then install java again , and the problem is solve .
It work for me!
