Installation & Licensing
32 bit and 64 bit under the same license
1 REPLY 1
jslee324
247 Views, 1 Reply
We are about to set up a 64-bit server to host terminal services and we would like to put our Auto-Cad on it as well as keep in on the office pc which is 32-bit. Can you download and run a 64-bit version under the same license as the current 32 bit or would there be another purchase involved?
1 REPLY 1
TravisNave
in reply to: jslee324
Hosting AutoCAD on terminal services is a violation of your license agreement.
You can, however, use Citrix as a means to get the results that you desire.  With network licensing, 32/64 CPU architecture does not matter.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
