Installation & Licensing
32 Bit Inventor Pro Install and Download Questions
2 REPLIES 2
536 Views, 2 Replies
Hello,   I have a older 32 bit machine,   there are 3 file downloads for Inventor Pro 2011,   the first is an exe, the next 2 are  zipped .rar files.
How do I proceed in installing after downloading these 3 files  ?   Do the other two  .rar files need unzipped first,  or do you just run the .exe  ?
any help on installing these 3 files onto  32 bit machine is appreciated.
thanks
-derek luff
Virginia community colleges
2 REPLIES 2
TravisNave
No, the first .exe file will self-extract the other two automatically.  They will extract into a folder and then you can run setup from there.  Make sure you have local admin rights, UAC is off, and anti-virus is disabled.  Good luck!
Autodesk Forums:
in reply to: TravisNave
thank you much,  I will follow that protocol.
Administrator Productivity
