Hi all,
I am trying to install the above product and get a series of appdata errors. cant open the device or file specified
Any help would be nice
Solved by WILLIAMF. Go to Solution.
Solved by avto. Go to Solution.
Hi @WILLIAMF,
Would you mind providing a copy of your installation log so we can look a little deeper into the install error? Thanks!
Sure, but where do I obtain that info? I did not see it when the installation failed
Hi William,
"The system can not open the device or file specified" typically relates to a running antivirus (usually Trend Micro) blocking the product installation process.
We have the following post on our Up and Ready blog regarding it.
Then please follow general installation workflow as per following post, the link below.
http://upandready.typepad.com/up_and_ready/2013/04/quick-start-general-installation-workflow.html
Best regards,
Thats exactly the virus protection we use. Trend anti virus. I will ask the I.T. guy to disable and try again.
Had problems downloading from website and even the stick that I requested.
Problem resolved.
Turn off Trend Virus protection and the software loads seamlessly.
Thanks to all
Bill
