Installation & Licensing
2015 APDS Deployment Fails
2 REPLIES 2
karthur1
365 Views, 2 Replies
I have used my deployment on several other systems without issues, but on this one system it does not install.  The installation starts, but after it completes the VB C++ 2005 (Redistributable) it stops.  No log file is created, however, when I look in the %temp% folder, I do see a log file "vcredist_x86_2005.log".  Toward the bottom of this file, it shows this 1708 error code:
I have tried/checked this:
uninstalled the Microsoft Visual C++ 2005 Redistributable and re-ran deployment.
UAC is set to never notify and Antivirus is disabled.
programdata\Autodesk folder has full control
Logged in as Administrator.
What can I do to figure out what is blocking this install?
Kirk
2 REPLIES 2
TravisNave
in reply to: karthur1
You could install the prereq manually, then modify the setup.ini file to remove the check for the prerequisite.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
karthur1
in reply to: TravisNave
I edited the deployment .ini file and added the "IGNORE_FAILURE=YES" line after the EXE_PARAM line in the VCredist2005 section.
Its seems to be installing now.
Kirk
Administrator Productivity
