Installation & Licensing
2014 Deployment location changes when I modify deployment
5 REPLIES 5
karthur1
403 Views, 5 Replies
I created a deployment and saved it on a location on the server that is shared.  Next, I needed to modify the deployment to add a service pack that was added.  I logged into the server where the deployment was using a Remote Terminal at my workstation.  After I modified the deployment, it lists my workstation as the location that the deployment should be ran from.  This location is not shared and I would like it to be ran from the original locaton on server.
Is there a way to make it place the modified deployment in the same location as the original deployment?
Here is what I see after the deployment is modified.
Kirk
5 REPLIES 5
asburyj
in reply to: karthur1
Did you create the deployment on one server and then copy it to a new server or did perhaps the servername change? It appears that the original server location was KARTHUR-7 so if that is changed you will want to recreate your deployment.
Jeffry Asbury
karthur1
in reply to: asburyj
I orginally created the deployment on the fmi2 server (using remote desktop from karthur workstation).  The server name has never been changed nor has the deployment been copied.
asburyj
Perhaps the incorrect location was entered when creating it? I would suggest recreating the deployment at this point
Jeffry Asbury
karthur1
Would have never used that location when I created the deployment.  I will recreate it.
asburyj
Your other option would be manually editing though the ini file for the deployment and manually changing the target for the links but my recomendation if just for recreation since you are needing to add in a service pack anyway.
Jeffry Asbury
Administrator Productivity
