Installation & Licensing
karthur1
Message 1 of 6 (222 Views)
2014 Deployment location changes when I modify deployment
222 Views, 5 Replies
12-04-2013 05:53 AM
I created a deployment and saved it on a location on the server that is shared.  Next, I needed to modify the deployment to add a service pack that was added.  I logged into the server where the deployment was using a Remote Terminal at my workstation.  After I modified the deployment, it lists my workstation as the location that the deployment should be ran from.  This location is not shared and I would like it to be ran from the original locaton on server.
Is there a way to make it place the modified deployment in the same location as the original deployment?
Here is what I see after the deployment is modified.
Kirk
Product Support
asburyj
Message 2 of 6 (209 Views)
Re: 2014 Deployment location changes when I modify deployment
12-04-2013 11:19 AM in reply to: karthur1
Did you create the deployment on one server and then copy it to a new server or did perhaps the servername change? It appears that the original server location was KARTHUR-7 so if that is changed you will want to recreate your deployment.
Jeffry Asbury
karthur1
Message 3 of 6 (207 Views)
12-04-2013 11:31 AM in reply to: asburyj
I orginally created the deployment on the fmi2 server (using remote desktop from karthur workstation).  The server name has never been changed nor has the deployment been copied.
Product Support
asburyj
Message 4 of 6 (202 Views)
12-04-2013 12:46 PM in reply to: karthur1
Perhaps the incorrect location was entered when creating it? I would suggest recreating the deployment at this point
Jeffry Asbury
karthur1
Message 5 of 6 (198 Views)
12-04-2013 01:08 PM in reply to: asburyj
Would have never used that location when I created the deployment.  I will recreate it.
Product Support
asburyj
Message 6 of 6 (196 Views)
12-04-2013 01:10 PM in reply to: karthur1
Your other option would be manually editing though the ini file for the deployment and manually changing the target for the links but my recomendation if just for recreation since you are needing to add in a service pack anyway.
Jeffry Asbury
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
