Installation & Licensing
2013 cancels during install
3 REPLIES 3
compassray
390 Views, 3 Replies
I tried installing from DVD twice, each time it cancels the installation when it gets to 11 of 14 on installation which shows it's loading the Materials Library. Anybody having the same problem.
3 REPLIES 3
TravisNave
in reply to: compassray
Do you have the old one still installed?
Autodesk Forums:
compassray
in reply to: TravisNave
Yes 2012 was still installed. I seem to have found the solution. I tried installing again the previous 2 times I had selected to also install AutoDesk Design Review, this time I unselected it and it installation was a success.
TravisNave
Excellent.  That was exactly what I was leading towards.  Glad you figured it out and posted the follow-up.
Autodesk Forums:
Administrator Productivity
