Installation & Licensing
2013 Revit Architecture Install Error
7 REPLIES 7
Message 1 of 8
mfrietze
4568 Views, 7 Replies
I keep getting errors when I try to Install Revit 2013.
I've already installed all my windows updates, turned off firewalls/antivirus, and uninstalled C++
Any and all suggestions would be appreciated!
Thanks!
Mia
this 1309 error:
but when i check that file DOES exist.
and here are the two set up logs:
2012/5/17:17:25:24 paul MMA07 === Setup started on MMA07 by paul === 2012/5/17:17:25:24 paul MMA07 Launch 2012/5/17:17:26:41 paul MMA07 === Setup ended ===
2012/5/17:17:25:49 paul MMA07 === Setup started on MMA07 by paul === 2012/5/17:17:25:49 paul MMA07 Launch 2012/5/17:17:26:05 paul MMA07 PageOpen LaunchDialog   2012/5/17:17:26:09 paul MMA07 PageOpen LicenseDialog   2012/5/17:17:26:11 paul MMA07 PageOpen ProductInfoDialog   2012/5/17:17:27:28 paul MMA07 PageOpen ProductSelectionDialog2   2012/5/17:17:40:32 paul MMA07 PageOpen FullProgressDialog   2012/5/17:17:40:32 paul MMA07 Installing Microsoft Visual C++ 2005 Redistributable (x86): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PAUL~1.MMA\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/5/17:17:40:54 paul MMA07 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2012/5/17:17:40:54 paul MMA07 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2012/5/17:17:41:16 paul MMA07 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded  2012/5/17:17:41:16 paul MMA07 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2012/5/17:17:41:27 paul MMA07 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded  2012/5/17:17:41:27 paul MMA07 Installing DirectX® Runtime: \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/5/17:17:46:19 paul MMA07 Install DirectX® Runtime Failed Failure is ignored, Result=-9 2012/5/17:17:46:19 paul MMA07 Installing FaroSDK: \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\PAUL~1.MMA\AppData\Local\Temp\FaroSDK.log" 2012/5/17:17:46:44 paul MMA07 Install FaroSDK Succeeded  2012/5/17:17:46:47 paul MMA07 Installing Autodesk® Revit® Architecture 2013:  TRANSFORMS="\\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\x64\en-us\RAC2013\RAC2013.mst;C:\Users\PAUL~1.MMA\AppData\Local\Temp\_AIF076.tmp\x64\RAC2013\RAC2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="\\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/5/17:17:50:21 paul MMA07 Install Autodesk® Revit® Architecture 2013 Failed Installation aborted, Result=1603 2012/5/17:17:50:21 paul MMA07 Rollback FaroSDK Failed Failure is ignored, Result=1619 2012/5/17:17:50:21 paul MMA07 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2012/5/17:17:50:21 paul MMA07 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2012/5/17:17:50:21 paul MMA07 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2012/5/17:17:50:26 paul MMA07 PageOpen InstallCompleteDialog   2012/5/17:18:21:29 paul MMA07 === Setup ended ===
2012/5/17:18:36:40 paul MMA07 === Setup started on MMA07 by paul === 2012/5/17:18:36:40 paul MMA07 Launch 2012/5/17:18:37:14 paul MMA07 === Setup ended ===
2012/5/17:18:36:49 paul MMA07 === Setup started on MMA07 by paul === 2012/5/17:18:36:49 paul MMA07 Launch 2012/5/17:18:36:59 paul MMA07 PageOpen LaunchDialog   2012/5/17:18:39:41 paul MMA07 PageOpen LicenseDialog   2012/5/17:18:39:44 paul MMA07 PageOpen ProductInfoDialog   2012/5/17:18:40:31 paul MMA07 PageOpen ProductSelectionDialog2   2012/5/17:18:40:59 paul MMA07 PageOpen FullProgressDialog   2012/5/17:18:41:00 paul MMA07 Installing Microsoft Visual C++ 2008 Redistributable (x64): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\PAUL~1.MMA\AppData\Local\Temp\vcredist_x64_2008.log 2012/5/17:18:41:05 paul MMA07 Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded  2012/5/17:18:41:05 paul MMA07 Installing Microsoft Visual C++ 2005 Redistributable (x86): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PAUL~1.MMA\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/5/17:18:41:26 paul MMA07 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2012/5/17:18:41:26 paul MMA07 Installing Microsoft Visual C++ 2005 Redistributable (x64): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x64\VCRedist\2005\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PAUL~1.MMA\AppData\Local\Temp\vcredist_x64_2005.log"" " 2012/5/17:18:41:47 paul MMA07 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded  2012/5/17:18:41:47 paul MMA07 Installing Microsoft Visual C++ 2008 Redistributable (x86): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x86\VCRedist\2008\install.exe /q /l C:\Users\PAUL~1.MMA\AppData\Local\Temp\vcredist_x86_2008.log 2012/5/17:18:41:55 paul MMA07 Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded  2012/5/17:18:41:55 paul MMA07 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2012/5/17:18:42:06 paul MMA07 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded  2012/5/17:18:42:06 paul MMA07 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2012/5/17:18:42:17 paul MMA07 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded  2012/5/17:18:42:17 paul MMA07 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PAUL~1.MMA\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/5/17:18:42:42 paul MMA07 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded  2012/5/17:18:42:43 paul MMA07 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PAUL~1.MMA\AppData\Local\Temp\vcredist_x64_2005.log"" " 2012/5/17:18:42:55 paul MMA07 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded  2012/5/17:18:42:55 paul MMA07 Installing DirectX® Runtime: \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/5/17:18:45:25 paul MMA07 Install DirectX® Runtime Failed Failure is ignored, Result=-9 2012/5/17:18:45:25 paul MMA07 Installing FaroSDK: \\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\PAUL~1.MMA\AppData\Local\Temp\FaroSDK.log" 2012/5/17:18:45:49 paul MMA07 Install FaroSDK Succeeded  2012/5/17:18:45:52 paul MMA07 Installing Autodesk® Revit® Architecture 2013:  TRANSFORMS="\\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\x64\en-us\RAC2013\RAC2013.mst;C:\Users\PAUL~1.MMA\AppData\Local\Temp\_AI80E2.tmp\x64\RAC2013\RAC2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="\\MMASERVER01\public\MMA\MMA Program Downloads\2013 Revit Suite\Autodesk_Revit_Architecture_2013_English_Win_32bit-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/5/17:18:48:25 paul MMA07 Install Autodesk® Revit® Architecture 2013 Failed Installation aborted, Result=1603 2012/5/17:18:48:25 paul MMA07 Rollback FaroSDK Failed Failure is ignored, Result=1619 2012/5/17:18:48:25 paul MMA07 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619 2012/5/17:18:48:25 paul MMA07 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619 2012/5/17:18:48:25 paul MMA07 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2012/5/17:18:48:25 paul MMA07 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2012/5/17:18:48:25 paul MMA07 Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619 2012/5/17:18:48:26 paul MMA07 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2012/5/17:18:48:26 paul MMA07 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2012/5/17:18:48:26 paul MMA07 Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619
and
7 REPLIES 7
Message 2 of 8
DannyHubbard
in reply to: mfrietze
This is probably because the path to the files is exceeding 260 characters. Try renaming the folder "Autodesk_Revit_Architecture_2013_English_Win​_32bit-64bit" to something like "Revit_Architecture_2013" and try the install again. You may need to rename or shorten some of the other folders as well.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 3 of 8
mfrietze
in reply to: DannyHubbard
That did the trick!  Thanks!
Message 4 of 8
TravisNave
There really needs to be an understanding here that the UNC path for deployments needs to be \\server\share and not some long drawn out folder path.  If you want to conform to some kind of standards where you have everything organized into a huge forest of folders, that is fine.  However, once you have gotten down to the very last folder for your C:\Installs\clients\PCs\Favorite_Color\Windows\64bit\Autodesk\2013\AutoCAD\Vanilla\For_Engineering\Frank_Only\HomeComputer\With_SP1\Stand_alone_License\Subscription\Deployment, then only share that last folder!  \\server\deployment.  That way you get to keep your ridiculous pathing rules, but the installer still works within its limits.  Smiley Very Happy
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 8
asgoudarzi
I am getting error 1619 I renamed the folder to make it short and also removed all C++ programes but it didn't work for me. Any thought on this?
Message 6 of 8
TravisNave
in reply to: asgoudarzi
Error 1619 might be a corrupted install.  Consider downloading it again.
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
Autodesk Forums:
Message 7 of 8
acapela7
I have installed my Revit Architecture 2013 and I found that the Sketch mode is not working properly,(sometimes the Edit Boundary  mode does not appear), I have installed it several times but still have the same problem, Maybe if I download it on line instead of the disk may help? I do not know. Can anyone help me on that?
Message 8 of 8
TravisNave
in reply to: acapela7
Please post in this forum, for better results:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/bd-p/133
Autodesk Forums:
Administrator Productivity
