Installation & Licensing
Active Member
jagrove
Message 1 of 21 (5,048 Views)
2013 Install Process
5048 Views, 20 Replies
04-12-2012 08:07 AM
I created an AutoCad Electrical 2013 deployment and went to install it on a client computer to have it sit in the Setup Initialization phase for hours. ( I left it over night)
I don't get any prompts to answer, the progress bar fills up and then retreats back to half full.  It continues this for as long as you let it.
I modified the deployment and it didn't help.  Any help would be appreciated.
Thank you!
TravisNave
Message 2 of 21 (5,028 Views)
Re: 2013 Install Process
04-12-2012 05:39 PM in reply to: jagrove
Modify the deployment.  Do not make it a silent install.  Post any installation error logs that get created.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Employee
RobinShou-Autodesk
Message 3 of 21 (5,019 Views)
04-12-2012 07:28 PM in reply to: jagrove
Please try to recreate the deployment, and make it unsilent install in the same page which you put the deployment name and path in. After that try to install from the new deployment.
Let me know if you still have the same issue, and also attache the log files from %temp% folder.
Robin Shou
Quality Assurance
AutoCAD Electrical
Member
Message 4 of 21 (4,864 Views)
05-23-2012 06:04 AM in reply to: RobinShou-Autodesk
Did this issue ever get resolved? I am having the same problem with Electrical 2012. Win 7 and XP both display this issue. I am an admin user.
New Member
Message 5 of 21 (4,733 Views)
07-01-2012 08:52 PM in reply to: jagrove
Same issue here. I left my install going for ages and it sat on "Initializing setup" for the entire time. This prompt has a scroll bar that inifinitlely loops and when I look at taskmgr I can see that the setup*32.exe has been called but nothing else has (dotnet 4 I think is called first during a normal setup).
Cpu usage sits on nothing and Network usage bursts to about 3% when the deployment starts but drops to 0% after a few seconds.
Nothing in the event logs that is helpful, no warning or errors or completions around this.
Interestingly enough though once I remade the deployment share (not from scratch, I used the existing files) without the silent install paramter it all went through the setup fine.
Also, the log is not created when I had the silent install option enabled so it's not even at that stage when it's halting.
Member
Message 6 of 21 (4,545 Views)
08-07-2012 08:49 AM in reply to: RobinShou-Autodesk
Hello RobinShou,
I was having the same problem with AutoCAD and AutoCAD Civil 3D 2013 32-bit and 64-bit Deployments, with the AutoCAD Setup Initialization being stuck on initializing.  Your suggestion about re-creating the deployment ("run silent" was already off) did the trick.  I can now do the various deployments!
Thank you,
John L., Civil CADD Manager
Active Member
Message 7 of 21 (4,516 Views)
08-08-2012 06:35 AM in reply to: jagrove
Hi, i even has the same problem with Autodesk Product Design Suite 2013. Setup is initializing are hanging and nothing more happens. I will try to uncheck silent install as well. Autodesk, whats in this problem? Solutions avalible for Win 7 ?
I can see an solution on the Up an ready blog regadrs this problem on Win XP x64. What abaout Win 7 ?
Member
Message 8 of 21 (4,514 Views)
08-08-2012 07:17 AM in reply to: jagrove
This problem that happened to me (AutoCAD 2013 & AutoCAD Civil 3D 2013) had occurred on both Windows XP Pro 32-bit and Window 7 Pro 64-bit OS. I did a "Re-create Deployment" option under tools in the deployment folder, and it did the trick. No more stuck on "Initializing". Thank you, John L. Lund [Logoletter25x25] John L. Lund Civil CADD Manager Civil CADD Section, Engineering Division Yuma County Dept. of Development Services Telephone: (928) 817-5115 john.lund@yumacountyaz.gov 2351 W. 26th St Yuma, AZ, 85364 Fax: (928) 817-5020 www.yumacountyaz.gov
Message 9 of 21 (3,953 Views)
10-31-2012 08:46 AM in reply to: john.lund
Same problem here.  Trying to create a working Civil 3D 2013 deployment but it sits at the Setup Initialization window forever.  No network log file is ever created, it must not get that far.  While I don't see a "Re-create deployment" option in the tools folder of the deploy, I used the "create & modify deployment" shortcut to modify it, however, I had already unchecked the silent install option.  I even created the deploy again with the silent option checked, just so I could "modify" the deployment to uncheck it (thinking maybe it's just a bug of some sort).  None of that helped and I am still stuck trying to create a working deployment.
Any other ideas?
Member
Message 10 of 21 (3,950 Views)
10-31-2012 08:49 AM in reply to: jagrove
I ended up re-creating the deployment and that fixed my issue.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
