• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    2013 Civil 3D Install Issues
    104 Views, 1 Replies
    03-06-2013 08:56 AM
    I have just downloaded the 30 day trial of Civil 3D and am having issues completing the install. I run the steup.exe file, it brings up the initializing screen, and always errors with the message:
    "The system cannot open the device or file specified.
    C\Users\AppData\Local\Temp\_AI8556.tmp\x86\en-us\Componets\adr2013\SetupDesign2013.msi"
    The "_AI8556" part changes every time I try to open it, but the rest stays the same. I have admin access on this computer. I'm also unsure why the "x86" part comes up when I am trying to install the 64 bit version of the software. If anyone has any ideas that may help me complete the install, please reply. Thank you.
    Please use plain text.
    TravisNave
    Re: 2013 Civil 3D Install Issues
    03-08-2013 07:17 AM in reply to: CameronPerry
    A lot of this lately is caused by anti-virus protection.  Make sure it is disabled, UAC is off, and you have local admin rights when installing.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
