Installation & Licensing
Distinguished Contributor
Dazzman
Message 1 of 10 (1,402 Views)
2012 default installation directory?
1402 Views, 9 Replies
04-06-2011 01:03 AM
I take it that in the new 2012 installer you no longer get the option to change the default directory name in to which AutoCAD installs on previous versions it was displayed the path i.e. c: C:\Program Files\Autodesk\AutoCAD 2011 in 2012 you just see the path C:\Program Files\Autodesk\ not the name of the directory in to which AutoCAD will be installed?
I don’t bother changing it it’s just that this time it installs to AutoCAD 2012 – English I take it that this makes it easier to install multiple language versions of the application in their native language directories?
So my real question is has AutoCAD become a regionalised installation or has someone forgot to include the installation directory path name in the installation or am I just not seeing it during my deployment installation?
Product Support
hashim.mundol
Message 2 of 10 (1,373 Views)
Re: 2012 default installation directory?
04-07-2011 12:21 AM in reply to: Dazzman
your observations are correct. there are various reason for this behaviour. one of them is to keep the installation process simple when it comes to bundled products; also it does help to install multiple language products side by side without user having to think about different directory for different language.
if you have any specific concerns for deployment we can address it differently
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Dazzman
Message 3 of 10 (1,370 Views)
04-07-2011 12:35 AM in reply to: hashim.mundol
Thanks for your reply.
I needed confirmation on how the default installation is configured for the 2012 products so that I could pass it on to our developers.
Valued Contributor
cpadilla
Message 4 of 10 (1,317 Views)
04-11-2011 02:55 PM in reply to: hashim.mundol
I'm only installing the English version, can I rename the "Autocad 2012-English" folder to just "ACAD 2012"?
Dazzman
Message 5 of 10 (1,284 Views)
04-13-2011 01:28 AM in reply to: cpadilla
I don’t think you can actually rename the installation folder you can only move its location.
New Member
vicleeber
Message 6 of 10 (1,199 Views)
04-29-2011 08:58 AM in reply to: Dazzman
Can someone tell me if this 2012 upgrade will install a new copy in addition to my already installed 2011?  I'm running an SSD drive and don't want two copies of cad on it.
Product Support
hashim.mundol
Message 7 of 10 (1,197 Views)
04-29-2011 09:00 AM in reply to: vicleeber
Yes it will.
you will have uninstall 2011 manually if you don't want use it.
Hashim Mundol
New Member
vicleeber
Message 8 of 10 (1,195 Views)
04-29-2011 09:06 AM in reply to: hashim.mundol
Thanks for the quick reply.  What folders/files should I save before uninstall?
Product Support
hashim.mundol
Message 9 of 10 (1,192 Views)
04-29-2011 09:15 AM in reply to: vicleeber
If you have space, I would recommend install 2012, then import custom settings and then uninstall 2011.
if you not, refer to the documentation(2012) on how to export/import the custom settings before uninstalling 2011.
Hashim Mundol
syria89
Message 10 of 10 (773 Views)
04-13-2012 01:16 PM in reply to: Dazzman
well i tried to install civil 3d 2012 in french then tried to install it in english it wont let me install it
the only way i am doing it right now is i modified the deployment and for the french version
i did add \FR in the deployement
C:\Program Files\Autodesk\Fr\
and the english i will do the same by adding \EN
C:\Program Files\Autodesk\EN
i will do the test and i let you know
i know it will work for autocad product based
but for example i dont think i will be able to install Revit FR and EN
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
