I have 2011 Civil 3D 64-bit installed and want to know what should be done before 2012 install. Thanks!
Solved by philip.s. Go to Solution.
Hi Greg,
You can have both versions installed on the same machine without running into functionality issues. The only reason that you would need to uninstall the 2011 software is if it was upgraded to the 2012 and the license is not on an active subscription agreement. If it is on subscription and or a new license was purchased, then you are entitled to keep both.
If my reply was helpful, please Kudo or Accept as Solution so that it can be more easily utilized by others.
