Installation & Licensing
New Member
carrielawson
Message 1 of 14 (1,013 Views)
2011 autocad lt from 32 bit to 64 bit
1013 Views, 13 Replies
09-04-2012 01:33 PM
I recently received a new PC with Windows 7 64 bit and I am trying to transfer my license and autocad to the new computer.  I already did the export license.  When i try to install autocad lt 2011 from the disc I had it gives me an error that this version will not work on my new computer.  Is this a 32 bit Windows 7 previous to now a new 64 bit Windows 7 issue?  If so, is there a download link for the 64 bit version so that I can install that and then transfer my license?   THANKS so much!
philip.s
Message 2 of 14 (1,009 Views)
Re: 2011 autocad lt from 32 bit to 64 bit
09-04-2012 01:41 PM in reply to: carrielawson
carrielawson - here's a 24hr timed direct download link for the 64BIt software.
AutoCAD LT 2011 - 64BIT - LINK
Philip Schmelzer
New Member
carrielawson
Message 3 of 14 (1,001 Views)
09-04-2012 03:54 PM in reply to: philip.s
thank you Phillip,  the link and activation worked.
New Member
bpesys
Message 4 of 14 (872 Views)
11-06-2012 08:21 AM in reply to: carrielawson
I am having the same issue with Autocad LT 2012, could you give me a link to download the 64 bit software? Thanks.
philip.s
Message 5 of 14 (867 Views)
11-06-2012 09:58 AM in reply to: bpesys
Here you go bpesys!
AutoCAD LT 2012 - 64 BIT - LINK
Please not that for future reference you can also request replacement media and or previous version download links (if available) directly via this link.
Philip Schmelzer
New Member
jd.barnidge
Message 6 of 14 (639 Views)
04-18-2013 01:21 PM in reply to: carrielawson
I'm having the same issue with a new Windows 7 64bit computer. Have a license/package for Windows 7 32 bit. Need the 64bit downloadable version.
Thanks.
philip.s
Message 7 of 14 (633 Views)
04-18-2013 03:49 PM in reply to: jd.barnidge
Hi JD,
Most current + supported previous version software titles can be accessed via Matt, our Virtual Assistant.
Philip Schmelzer
Member
LarsonData01
Message 8 of 14 (317 Views)
03-04-2014 01:01 PM in reply to: philip.s
About a year and half I transferred my license from a 32bit to a 64 bit and now I am moving to a new pc again. Do I need the download for the 2011 autocad LT 64 bit to get it to work on my new pc running windows 7 64 bit.
pendean
Message 9 of 14 (313 Views)
03-04-2014 02:14 PM in reply to: LarsonData01
Did you save the original 64bit download file? Then you can use it.
If not (not sure why not), you can grab antoher copy, and this time actually save it somewhere save:
1. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Select the choice "Download Links".
3. Select your product, then variant, then version as applicable.
4. You should now be presented with the choice to download your software.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
LarsonData01
Message 10 of 14 (305 Views)
03-05-2014 08:58 AM in reply to: pendean
I am not sure why but after I install Autcad LT 2011 and try to run the
program it restarts the installation process over again. I have tried
running the program from both the icon on the desktop and the start menu,
restarting the pc, and running the installation fresh as an administrator.
what could I be missing that would cause it to rerun the installation?
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
