• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Accepted Solution
    2011 autocad lt from 32 bit to 64 bit
    451 Views, 6 Replies
    09-04-2012 01:33 PM
    I recently received a new PC with Windows 7 64 bit and I am trying to transfer my license and autocad to the new computer.  I already did the export license.  When i try to install autocad lt 2011 from the disc I had it gives me an error that this version will not work on my new computer.  Is this a 32 bit Windows 7 previous to now a new 64 bit Windows 7 issue?  If so, is there a download link for the 64 bit version so that I can install that and then transfer my license?   THANKS so much!
    Please use plain text.
    philip.s
    Re: 2011 autocad lt from 32 bit to 64 bit
    09-04-2012 01:41 PM in reply to: carrielawson
    carrielawson - here's a 24hr timed direct download link for the 64BIt software.
    AutoCAD LT 2011 - 64BIT - LINK
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    New Member
    09-04-2012 03:54 PM in reply to: philip.s
    thank you Phillip,  the link and activation worked.
    New Member
    11-06-2012 08:21 AM in reply to: carrielawson
    I am having the same issue with Autocad LT 2012, could you give me a link to download the 64 bit software? Thanks.
    philip.s
    11-06-2012 09:58 AM in reply to: bpesys
    Here you go bpesys!
    AutoCAD LT 2012 - 64 BIT - LINK
    Please not that for future reference you can also request replacement media and or previous version download links (if available) directly via this link.
    Philip Schmelzer
    TW | PI | YT | BLOG
    New Member
    04-18-2013 01:21 PM in reply to: carrielawson
    I'm having the same issue with a new Windows 7 64bit computer. Have a license/package for Windows 7 32 bit. Need the 64bit downloadable version.
    Thanks.
    philip.s
    04-18-2013 03:49 PM in reply to: jd.barnidge
    Hi JD,
    Most current + supported previous version software titles can be accessed via Matt, our Virtual Assistant.
    Philip Schmelzer
    TW | PI | YT | BLOG
