Installation & Licensing
292 Views, 1 Reply
2011 Inventor Install
I made an attempt to load my 2011 Inventor subscription software last Friday. In the middle of the install my computer became unstable.
I restarted the install after re-booting my PC and the DVD prompted me that 2011 was already loaded.
Please Help,
Jerry Goad
1 REPLY 1
TravisNave
You can try a repair install from Add/Remove programs.  If that fails, remove the product.  You may have to use the Microsoft Installer Clean-up Utility. If so, I have posted the file for download here:
http://forums.autodesk.com/t5/Installation-Licensing/help/td-p/2705337/highlight/true/page/2
Once removed, you should be able to install successfully.
Autodesk Forums:
Administrator Productivity
