I originally installed Autocad 2010LT from a trial disk. When the trial expired I bought the product. I was issued a serial number and activation text file and activated the product. Now I want to move to a different computer. If I use the License Transfer Utility, I can only import the license if it is the same serial number but if I install Autocad from the original trial disk, will that disk have the same serial number or was the serial number assigned at the time I bought the product? In any case, how do I move Autocad 2010LT to a new machine? Thanks.
Solved by pendean. Go to Solution.
The demo has no hard-coded serial number, any LT2010 product disk will do to get you back up, as will the LTU. All you need is the PURCHASED serial number that was issued to you after you paid someone a lot of money for it.
