The registration and license transfer transactions go through the port 443
(SSL), not 80. Also make sure you don't have your Internet Explorer in the
"Off-line mode".
Vladimir Michl, http://www.xanadu.cz http://www.cadforum.cz
píše v diskusním příspěvku
news:6171445@discussion.autodesk.com...
Hi, I'm trying to import a registered license file which I've exported from
my PC onto Autodesk's license transfer server onto a pc which is behind a
corporate firewall & am having zero luck.. I have the same issue when trying
to register the 2nd PC also I have internet access fine & even thou I've
raised this with Autodesk in the past, they won't accept the fact that some
firewall settings won't allow the registration wizard or license transfer
wizard through. Now from what I've been told from Autodesk, the wizard's all
use port 80 & this is open on the network, but the wizard comes back with
the following: "No internet connection was detected. To Transfer a license,
connect to the internet now." So, here I am with a live internet connection,
writing this post and with the comments from Autodesk that the license
registration & transfer wizards use port 80, but I'm still unable to
activate or transfer a license. Does anyone have any idea what I can try on
my end to try and import my license. It used to be great when I could simply
stick the license on a USB stick and go from PC to PC with no worries. Now
the system is a real pain for folks like me who are behind a corporate
firewall or those who are mobile and do not have connections to the web. Any
help would be most appreciated. Thanks Devon
