• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    2010 Installation Problem
    331 Views, 5 Replies
    04-21-2010 10:10 AM
    When we do an initial install of AutoCad 2010 and try to run the program we get a "Runtime Error R6034". We have had AutoCad send us a 2 duplicate disks and still get the error. Please advise.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: 2010 Installation Problem
    04-21-2010 10:37 AM in reply to: BoydChristensen8747
    This is not an Autodesk problem. It's actually a problem with your computer. You have mismatched C++ Runtime dlls on your OS that is causing this issue. You may need to reinstall your .NET Framework 3.5 SP1. What is your operating system?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    04-22-2010 05:47 AM in reply to: BoydChristensen8747
    We are running Vista.
    *Expert Elite*
    TravisNave
    04-23-2010 07:26 AM in reply to: BoydChristensen8747
    You may need to do a .NET Framework cleanup and reinstall .NET Framework 3.5 SP1. I would start there.
    Travis Nave
    Member
    01-16-2013 02:28 AM in reply to: BoydChristensen8747
    Can you please say me where is the  .NET Framework Cleanup Tool ?
    *Expert Elite*
    TravisNave
    01-16-2013 10:21 AM in reply to: arquitt1995
