I have a standalone copy of AutoCAD LT 2007. I need to reinstall it on a new computer as the old one is dead. The original activation code does not work. I've requested new ones twice and they will not work either. Any help is greatly appreciated.
Hi Matthew and welcome to the Autodesk Community!
I just looked up your license as it is associated to your email address, and found that it has been activated three times today. As you have a single seat license, you only get two automated activations. After that, you will need to request a manual activation by our Activation and Registration team:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus.
4. Select “I Still Need Help” if you need personal assistance.
Please note that each activation code an only be used one time per activation. Any activation after that will require a new code which can be provided by the Activation and Registration team above.
If you have any other questions please reply to this post. Thank you!
