Hi Kyle,
I actually leave the acad.lsp there. Depending on what you're doing with
the acad.lsp, this may or may not be okay.
If you are loading a profile, you can say if the profile does not exist,
load it. Leaving the acad.lsp there would not be an issue in this case.
You could add a network path to the top of the support file search path,
place a different acad.lsp there (that does something different or very
little), and use that acad.lsp from then on.
Sincerely,
Drew
CMI
"Kyle Vargas" wrote in message
news:4885291@discussion.autodesk.com...
Hi Drew,
I like the idea of creating and adding an acad.lsp to the deployment. Just
out of curiosity, how are you handling the acad.lsp after installing the
deployment? I guess you could have the routine erase the acad.lsp after
setting up the various features.
Kyle Vargas
Morton & Pitalo, Inc.
"Drew Burgasser" wrote in message
news:4885246@discussion.autodesk.com...
I created an acad.lsp to do a good portion of this customization for ldt,
and added that file to the deployment as a custom file. Inside the
acad.lsp, you can do things like set support paths, load profiles, create
folders, set variables, etc.
Sincerely,
Drew Burgasser
CAD Masters, Inc.
