Mike,
This error appears to be known for Inventor products but I am not familiar
with it being a problem with AutoCAD 2004 when installing the NLM. A
suggestion I would make is to try copying the \EULA directory to the root of
C:
Hope this helps,
Simon Gillis
Autodesk Professional Services
"Mike Burke" wrote in message
news:tb0sav0m85526k4857e3insbtvegb47j4v@4ax.com...
> I am trying to install the 2004 version of FlexLM onto a computer that
> is already running 3 other FlexLM Licensed software - 2002/Map 6,
> ArcView, and MathCAD.
> I had uninstalled the 2002/Map 6 Flex software prior to trying to
> install the 2004 version.
> When I start the setup.exe program, the first screen of the setup
> wizard displays, pauses for a second or two, and then the following
> dialog box displays...
> MSI3
> License Dialog
> File does not exist: \eula\AdskLicense.ini
> OK
> (sometimes the title shows MSI1 instead of MSI3)
> The file AdskLicense.ini is definitely there and in that directory. I
> copied the setup files and sub directories to the hard drive, but
> still get the same error when running the setup.exe from the hard
> drive.
> Has anybody experienced this?
> The computer I am trying to install the software on to is basically a
> license computer running different FlexLM versions for the software I
> listed above. We have been using it for about 2 years. It is running
> NT4 Workstation service pack 6, which is in the required specs to run
> the software.
> Thanks in advance.
> Mike
