Installation & Licensing
pat.kirley
193 Views, 2 Replies
2004 Borrow Help!
When I try to borrow a 2004 license I get an error message that says no licenses are available at this time and an error code: Error [1202.5.-67]. I've got 20 license with a LOWWATER_BORROW=15 so I should have 5 available for borrow. Any ideas on what to check would be greatly appreciated.
2 REPLIES 2
in reply to: pat.kirley
The LOWWATER setting includes licenses in use plus borrowed licenses. So if more than 5 seats are in use you will get this error and corresponding error. -- Jerry Milana, Autodesk Consulting "pat kirley" wrote in message news:3339649.1088108474231.JavaMail.jive@jiveforum1.autodesk.com... > When I try to borrow a 2004 license I get an error message that says no licenses are available at this time and an error code: Error [1202.5.-67]. I've got 20 license with a LOWWATER_BORROW=15 so I should have 5 available for borrow. Any ideas on what to check would be greatly appreciated.
bstaples
Does this work the same way for 2005? For example, I have 80 network licenses and I have a group defined in the options file of users who can checkout licenses. I set the lowwater value to 65. So if somebody needs to checkout a license, they have to be one of the first 15 to access a license or they will not be allowed to check one out?
Brian
Administrator Productivity
