Installation & Licensing
*Andrew Mallette
Message 1 of 4 (91 Views)
2002 to 2004
91 Views, 3 Replies
03-26-2004 07:41 AM
I've just got the new install for 2004. Currently we are running on license in a network through flexlm with autocad 2002, Now with 2004, can i install the network license on the existing license server and be fine, or do i need to update the license server and possibly have 2002 unavailable.
*jerry milana
Message 2 of 4 (91 Views)
Re: 2002 to 2004
03-26-2004 10:26 AM in reply to: *Andrew Mallette
Andrew, You will need the new license manager which will not coexist with the old one. The new one can service 2002 and 2004 licenses. Keep in mind that if you upgraded your 2002 licenses to 2004 you can only run 2002 for migration period as specified in your license agreement. See http://support.autodesk.com/getDoc.asp?id=TS66079 for information on setting up the license manager. -- Jerry Milana, Autodesk Consulting "Andrew Mallette" wrote in message news:40644f11_3@newsprd01... > I've just got the new install for 2004. Currently we are running on > license in a network through flexlm with autocad 2002, Now with 2004, > can i install the network license on the existing license server and be > fine, or do i need to update the license server and possibly have 2002 > unavailable. >
*Andrew Mallette
Message 3 of 4 (91 Views)
Re: 2002 to 2004
03-26-2004 10:45 AM in reply to: *Andrew Mallette
Thank you, that is what i needed to know, now to temp disable the 2002 while i update the license server software. I definetly will be migrating up to 2004 and the sooner the better. jerry milana wrote: >Andrew, > >You will need the new license manager which will not coexist with the old >one. The new one can service 2002 and 2004 licenses. Keep in mind that if >you upgraded your 2002 licenses to 2004 you can only run 2002 for migration >period as specified in your license agreement. See >http://support.autodesk.com/getDoc.asp?id=TS66079 for information on setting >up the license manager. > >
*Jimmy Bergmark
Message 4 of 4 (91 Views)
Re: 2002 to 2004
03-26-2004 11:02 AM in reply to: *Andrew Mallette
If you are on Autodesk Subscription check out the new license agreement that can let you have older versions as well as the latest version. -- Best Regards, Jimmy Bergmark CAD and Database Developer Manager at www.pharmadule-emtunga.com Take a look at JTB FlexReport (FLEXlm report tool) - www.jtbworld.com/jtbflexreport SmartPurger (Purges automatically) - www.jtbworld.com/?/smartpurger.htm or download some freeware at www.jtbworld.com More on AutoCAD 2005; www.jtbworld.com/autocad2005.htm "Andrew Mallette" wrote in message news:40647a4f$1_2@newsprd01... > Thank you, that is what i needed to know, now to temp disable the 2002 > while i update the license server software. I definetly will be > migrating up to 2004 and the sooner the better. > > jerry milana wrote: > > >Andrew, > > > >You will need the new license manager which will not coexist with the old > >one. The new one can service 2002 and 2004 licenses. Keep in mind that if > >you upgraded your 2002 licenses to 2004 you can only run 2002 for migration > >period as specified in your license agreement. See > >http://support.autodesk.com/getDoc.asp?id=TS66079 for information on setting > >up the license manager. > > > > >
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
