Installation & Licensing
Distinguished Contributor
raymondp
Message 1 of 4 (66 Views)
2002 SP!
66 Views, 3 Replies
02-06-2002 05:39 AM
I am begining a network installation of 2002, should I install SP1 on the deployment model before installing the clients?
What is ment by Locked and Unlocked versions of Autocad?
*Autodesk\
Message 2 of 4 (66 Views)
Re: 2002 SP!
02-06-2002 12:20 PM in reply to: raymondp
I would recommend for you to read the Service Pack
readme file where it outlines the procedure of applying SP to the network
deployments.  Briefly you need to apply the patch on the network image
using admin machine (machine you created the deployment from) and then apply it
to each individual client machine.
Even if you create client machines after
applying SP to the network image, you still have to apply it to the clients
anyway.
Service pack readme also talks about the difference
between locked and unlocked versions of AutoCAD.
Misha
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Autocad?
*B, Jimmy
Message 3 of 4 (66 Views)
Re:
02-07-2002 03:19 AM in reply to: raymondp
What is the reason then to apply  SP to the
image if you still have to apply it to the clients?
Is there a silent install option? And if not,
why?
Best regards: Jimmy B
CAD manager at
href="http://www.pharmadule-emtunga.com">www.pharmadule-emtunga.com
Take
a look at  the trialversion of SmartPurger or download some freeware
at
http://jtbworld.vze.com
Pack readme file where it outlines the procedure of applying SP to the network
it to each individual client machine.
clients anyway.
difference between locked and unlocked versions of AutoCAD.
Misha
I
Autocad?
*Autodesk\
Message 4 of 4 (66 Views)
Re:
02-07-2002 07:22 AM in reply to: raymondp
I was talking about network deploy of
the product which installs Program Files and the other vital parts of AutoCAD on
the server and only Shared files along with the desktop icon and cfg files
getting installed on the clients.  Obviously you need to patch both parts:
server and client.  That's why you need to apply the patch
everywhere.
Since the patch is an executable (not
MSP) file, standard MSI technique of silent install doesn't apply in this case
however since all you need to do is to run this executable anyway, all the
standard pushing tools can be used for that (SMS or others).  The only
difference would be that you will need to provide AutoCAD install image (as
patch requires original MSI) and you will also get a message that update
was applied successfully.
Misha
why?
CAD manager at
Take
at
network deployments.  Briefly you need to apply the patch on the
network image using admin machine (machine you created the deployment from)
and then apply it to each individual client machine.
clients anyway.
Misha
I
Autocad?
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
