Installation & Licensing
fawzimasri7137
Message 11 of 19 (297 Views)
Re: 2 Lmgrd process... is that expected
11-29-2010 02:15 PM in reply to: fawzimasri7137
Hi Emily,
after i applied the fix for the IPv6 that youu sent me, i was able to to keep IPv6 enabled on my computers, but more importantly my problem of obtaining a lic from server when the client was on the server as well, disaperraed... so i hit two birds in one stone..
thanks a bunch..
fawzi
New Member
ptrudeau
Message 12 of 19 (261 Views)
12-13-2010 08:48 AM in reply to: fawzimasri7137
FYI -
Do not do this on Microsoft Small Business Server. My experience, it shut down the exchange transport service
Pat
fawzimasri7137
Message 13 of 19 (257 Views)
12-13-2010 10:19 AM in reply to: ptrudeau
hmm.. i'll keep this in mind.
currrently i do not plan on puting the Lic Manager on our MS server 2003, i am sticking with win7 for now.
thanks for the heds up
Member
intanalazhar
Message 14 of 19 (66 Views)
07-25-2013 01:18 AM in reply to: fawzimasri7137
Emily,
I installed Infrastructure Design Suite but got same problem with fawzi, I already uncheck IPV 6 but doesn't work, attached log file for your check.
intan
Member
intanalazhar
Message 15 of 19 (63 Views)
Same error, Log File attched
07-25-2013 01:37 AM in reply to: intanalazhar
Emily,
the attachment was wrong, apologize attached the right one.
Regards
Intan
Product Support
emily.xu
Message 16 of 19 (58 Views)
Re: Same error, Log File attched
07-25-2013 02:17 AM in reply to: intanalazhar
Hi Intan
I didn't find any problem in the debug log. it looks good.  Can you give me the server status to check?  did you get -15 error on the client?
Emily Xu
TravisNave
Message 17 of 19 (51 Views)
07-25-2013 09:19 AM in reply to: intanalazhar
Intan,
Welcome to the community!
First, verify from the client that you can PING the server PC-10562 and get the expected IPv4 address.
PING PC-10562
If it is not an IPv4 address in the xxx.xxx.xxx.xxx format, but rather an IPv6 in a larger hex format, then you need to modify your hosts file to point the DNS name of the server PC-10562 to its correct IPv4 address on each client that accesses it.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Then using Internet Explorer (not a 3rd party browser) from the client verify that ports 27000 (lmgrd.exe) and 2080 (adskflex.exe) are open in the firewall on the server:
http://PC-10562:27000
http://PC-10562:2080
Each should respond with a jargon page on verification.  You should get a response similar to this:
Wê-60Wê-60Wê-60Wê-60Wê-60Wê-60
 If you get a 'Page cannot be displayed' or other 404 Error, then you have a port being blocked.
If you have any additional issues, please post them here.
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
intanalazhar
Message 18 of 19 (46 Views)
07-25-2013 11:27 PM in reply to: TravisNave
Thanks for the support,
Finally all functional now after I changed from Wifi to LAN Network, but the question is, how I can use Wifi? v.11.10 already used.
Intan
TravisNave
Message 19 of 19 (43 Views)
07-26-2013 08:55 AM in reply to: intanalazhar
You can use WiFi but you might need to increase the FLEXLM_TIMEOUT system environment variables of your clients as the thruput latency might be slower and cause connectivity timeouts.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
