Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln, Assistant Moderator
Autodesk Discussion Groups Forum Moderator Program
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
"colinm" <The
href="mailto:colin.murray@mclarenkvisia.com">colin.murray@mclarenkvisia.com>
wrote in message
href="news:f15b459.4@WebX.maYIadrTaRb">news:f15b459.4@WebX.maYIadrTaRb...
issue seems to be more basic than this.
ACAD2002 standalone will not run
on this system on any partition whatever I try. (Initially ACAD2002 was
installed on partition D:\ although I note C_DILLA installs/defaults to C:\).
The network version of ACAD2002 is however OK if installed on this system. The
above noted virus scanner patches have already been applied with no result. I
note also that if the portable license manager facility is started- it says
there is an "error trying to retrieve this machines Identification code."
Ideas?
"colinm" <I
wrote in message
href="news:f15b459.6@WebX.maYIadrTaRb">news:f15b459.6@WebX.maYIadrTaRb...
have now removed anything from this system that may be the source for this
problem, and halted almost all services, etc. I've also edited the registry
etc.
The summary is ACAD200o is OK, ACAD2002 network is OK, ACAD 2002 standalone
(the one required) has never worked on this system. Im logged is as full
administrator. The issue is C_DILLA cannot see the machine identifier and
therefore fails.
The error log "AutoCAD 2002 Adlm.err" includes the following fragment..
[916: 2003/4/29 - 22:58:27:128]
ThrownFile=..\adlmcd\CdaSelectTryAndExtendHandler.cpp
ThrownLine=218
AdlmError=17
AdlmVersion=1.0.0
OSMajorVersion=5
OSMinorVersion=0
OSBuildNo=2195
OSPlatform=2
OSExtraInfo=Service Pack 2
My only and final thought is that the W2000 machine name is of the format
A-NAAANNA-AAAA (where N is numeric, A alpha) - I wonder if C_DILLA has an
issue with a system name of this format ?? Other machine names where this is
works are all shorter without hyphens etc.
